Old 05-16-2021, 07:46 AM   #1
No heat or A/C from heat pump
Have a 2016 3011DS Forester. 58 degrees outside. Inside temp set at 68. Heat pump runs but provides no heat.
Drpelletier is offline   Reply With Quote
Old 05-16-2021, 09:06 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. Keep in mind a heat pump will only rase the temp between incoming cold air to outgoing warm air 20* at best 58 ambient 78 output. So the air you feel may not seem warm enough as compared to what a furnace would produce. Measure the cold air return and the output closet to the unit to see what the delta T is.
Retired Navy
2016 Flagstaff 26 FKWS
pump
