Originally Posted by Hankrebel
2016 grey wolf 26dbh
Fridge will only run on gas.
Previous owner said he replaced all the fuses but still woudnt run on electric.
I checked internal fuses and fuses on back of the fridge and all looked good.
When pressing the on switch, it will light up green(electric) for a few seconds and then immediately go amber(Gas). The light inside the fridge wont even come on with electric.
When its running on gas, it works fine and the light inside works.
Thoughts?
That doesn't make sense, the light is electric so it should work whether the fridge is running on electric or gas.
Can you get to the control board? Turn off the fridge, unplug from ac outlet, remove fuses, remove the wires from the terminals one at a time and put them back on, reinstall fuses, plug fridge back in and turn back on.
