This is my first post, and I've been pulling my hair out over this. I just purchased a 2018 Rockwood 2104S, and I'm having an issue with the furnace. It will run and heat, but I'm having some sort of short or something. When I step on the entry steps, I hear the furnace flame goes out then reignites, most of the time. It took a while to figure this out but, but I can step up and down on the step and the furnace flame will go on and off each time. The steps are bolted to the frame with no ground wires attached. This will happen if I'm hooked to 110 or not, or if I'm hooked up to my truck. I did have to move the trailer today, parked it, and the heater would not ignite. It would cycle through and turn off. Then when I parked it back in my drive way, furnace worked, but still had the flame/step problem. Any ideas are welcome.
