Originally Posted by Gatorbashr
With the help of some miscommunication with an electrical contractor I managed to blow my power inverter by connecting 220v to my Rockwood’s 120v plug.
Replaced power inverter, repaired the refrigerator and ac to dc inverter does charge the 12volt battery and all appears well on shore power now.
When I disconnect the shore power the only thing I get now is lights, slides, awning and jack.
Should the inverter work in reverse to power the 120v tv’s etc?
I assume you mean converter, not inverter.
You may have blown some other 12v fuses or the resettable circuit breaker up under the tongue. That's probably why only some things are working now.
Even though it fried your converter, there may have been a brief surge on the 12v side of things that did additional damage or hopefully just popped fuses or popped the circuit breaker in the tongue.
Edit - just reread your post i guess your 12v is ok you are asking about 120v plugs working. If your rig came with the inverter option typically provided as part of the solar package, some outlets usually tagged with a white label will work when you turn the inverter on. If you have one. It is separate from the converter, not the same box.
