Do you mean to hold the door open in storage?
If so there are usually plastic cards that clip in the frig locks in the instruction packet. I've been using short pieces of split pool noodle or foam pipe insulation jammed on the door extrusions for ventilation.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
