Old 07-19-2020, 07:55 PM   #1
Playing DVD in 2017 fr3
Trying to play DVD on front room tv using pioneer radio in front
Can anyone give step by step instructions
Jcthebear
Jcthebear is offline   Reply With Quote
Old 10-02-2020, 11:36 AM   #2
Jcthebear
I just purchased a 2019 FR3 32DS and also having trouble playing DVD on kitchen TV from the Pioneer head unit in the dash. The DVD will play on the outside TV. I've checked RC cable connections and pulled the head unit from the dash. Everything connected, but still can't get picture in kitchen. Anyone have a suggestion or fix?
2019 FR3 32DS is offline   Reply With Quote
Old 10-03-2020, 01:43 PM   #3
I had issues in my 2017 32DS, I tried putting the DVD in the player and I would change the input on the TV to the AV component and would get an error of no video source. After troubleshooting the issue I found that the video cable was plugged into the wrong port on the TV. This was difficult since I am tall and the ports are on the back of the TV pointing down. So I used a flash light to be able to read the labels on the TV.
So check to make sure the cables are plugged into the correct port. And mine has worked perfectly since.
2017 Forest River FR3 32DS
Retired Navy
Retired IT Professional
Blallen58 is offline   Reply With Quote
Old 10-03-2020, 05:51 PM   #4
rk06382's Avatar
Jcthebear
Download the FR3 Entertainment System Diagram 3-7-16 from the FR forum Library.
To see the RCA jacks on the TV, I stick my cell behind it & say 'cheese.'
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 12-03-2020, 09:57 PM   #5
Watching dvd from the dash unit
Do you have to keep the rv engine on to watch the dvd?
Laurasw is offline   Reply With Quote
Old 12-03-2020, 10:06 PM   #6
CC Traveler's Avatar
Our 2017 FR3 had a radio switch on the center console to turn on the radio while parked. You did not have to have your ignition on.
Mark & Connie
2023 Coachmen Concord 321DS
2006 GMC Canyon (Toad)
CC Traveler is offline   Reply With Quote
Old 12-03-2020, 10:06 PM   #7
Did you get step by step instructions? I wondering if the rv needs to be running to use the dvd player.
Laura
Old 12-04-2020, 03:25 PM   #8
The RV does not have to be running. I have a Radio switch that will turn the radio on when the engine is not running. As stated in a previous post, I found the video cable to be plugged into the wrong port of the TV. That fixed my issue. Make sure the input on your TV is set to AV.
Retired Navy
Old 12-04-2020, 03:30 PM   #9
Thank you....
Laura
Old 12-05-2020, 06:59 PM   #10
vacationlovers's Avatar
Post
This might be obvious, but hopefully everyone knows that you need 110v AC (from shore power or generator) for the TV.
2016 FR3 30DS
Thousand Oaks, CA
RV Trip Photos
vacationlovers is offline   Reply With Quote
Old 12-20-2020, 10:41 PM   #11
hdjimmi's Avatar
I clicked the link to the library but it just goes to the home page. Where is this located?
Retired and loving it
hdjimmi is offline   Reply With Quote
Old 12-21-2020, 03:40 AM   #12
rk06382's Avatar
Click the download button:
Robert
dvd, fr3
