Old 10-01-2020, 01:47 PM   #1
power antenna booster switch
Hi all,
Newbie here, just bought a 2021 Grey Wolf 20rdse in August. First tt for me and my wife and still learning the systems. Question is about the tv
antenna, when I press the power button on the face plate the green light
illuminates for a split second when I think is should stay solid. Either way
I do not receive any channel signals. Am I doing something wrong or should I call the dealer. This is the first time I have ever tried to hook
up a tv to it. Any ideas would be helpful.
Paul
trkdrvr76 is offline   Reply With Quote
Old 10-01-2020, 01:55 PM   #2
Just Tryin' to Help
cboss's Avatar
Give this a read:
https://www.rv.net/forum/index.cfm/f...print/true.cfm
There are a few ideas here and a few things to check.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 870
cboss is offline   Reply With Quote
Old 10-01-2020, 02:18 PM   #3
It's not impossible that you have a faulty switch on the faceplate. Just one idea.
TheWolfPaq82 is offline   Reply With Quote
Old 10-01-2020, 05:45 PM   #4
bubbles's Avatar
The booster (amplifier) is in the antenna; the light plate supplies the 12Vdc to the antenna. If there is a short (coax cable or amplifier) the plate is designed to shut down (light goes OFF) as a precaution. Sounds as though there is a coax cable short (coax (ground) to center conductor) assuming amplifier is not shorted.
Old 10-02-2020, 12:45 PM   #5
BillyBass's Avatar
On mind if I use cable my light has to be turn off and if I use antenna it got to be on.If that's any help
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
BillyBass is offline   Reply With Quote
Old 10-02-2020, 01:10 PM   #6
Mr. Dan's Avatar
That doesn't answer why the light comes on for a second and goes back off without any human action.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 0
Old 10-02-2020, 01:48 PM   #7
BillyBass's Avatar
I miss read that then .I guess I cant help you there
Old 10-02-2020, 06:52 PM   #8
Just as confused as you
Scrapper's Avatar
I agree with bubbles on this one. Hopefully, you have a short in the coax, either at the antenna head or the connection on the plate as those are the easiest and less costly to repair. If it's a short in the antenna's amplifier or a bad switch plate you will have to contend with the dealer's service department and who knows how long that will take.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
antenna, power, switch
