Old 05-23-2021, 08:13 AM   #1
Power watchdog keeps saying line 1 voltage error
Hello
Recently had our service line upgraded from 30 amp to 50 amp. Have a Hughes autoformers Power WatchDog hooked up. Seems I keep getting a “Line 1 voltage error” meaning the voltage has exceeded 132 or dropped below 104 volts.
Is this common, meaning these devices are just doing their job or do I have an issue? The unit resets after it senses proper voltage after 90 seconds but just more annoying that it resets our fridge to a lower setting lol.
Should add that I’m at a permanent site with ComEd Smart Meters (Illinois).
ID:	255132Click image for larger version
Chad_P is offline   Reply With Quote
Old 05-23-2021, 08:31 AM   #2
Does this coincide with something starting (like an AC) or is it just random?
TT - 2021 Rockwood 2608BS
TV - 2020 F-250 XLT 4WD SRW 6.2L gas
mac1_131 is offline   Reply With Quote
Old 05-23-2021, 08:32 AM   #3
wmtire's Avatar
Are you noticing this with certain appliances running?
The reason I am asking is do you notice this happen when certain loads are being applied. Can you possibly (and safely) check to make sure your neutral is fastened correct and not loose. However if you are not familiar with electricity, please do not do this.
An open/loose neutral can cause funky things to happen, especially when loads are applied.
Check this link out, and then click on the "open neutral" tab
https://www.myrv.us/electric/
2011 Flagstaff 831 RLBSS
If fridge is the shortened form of refrigerator, where did that "d" come from?
Old 05-23-2021, 08:41 AM   #4
Thanks! Haven’t been able to pinpoint, if anything it’s happening at night. Has happened twice this weekend.
We did have the electrician out last week as the 50 amp breaker was faulty and the Power Watchdog caught it. Was only getting 20 volts on one line. Replaced the breaker last week and the electrician checked the connection and all seemed well. Think it’s worth having him come back out?
Old 05-23-2021, 08:45 AM   #5
wmtire's Avatar
A few years ago, I was getting weird power things happening in my shop. I could turn on lights on one side and it would affect the lights in another building (even though they are on two different circuit breaker panels). I knew it was probably an open neutral somewhere. The power company came out to test, and it happened to be on the transformer, where the neutral blew out (according to their words). They had just replaced the transformer a few days previously.
Very weird things can happen with a loose or open neutral with 120/240 volt split phase electricity. Here is a pic I took at the time pointing at the neutral hanging down.
Old 05-23-2021, 08:51 AM   #6
wmtire's Avatar
This is an article I link to a lot that explains in simple terms 120/240 volt power and 50 amp RV's with the role of the neutral wire. This may or not be your problem, but it's worth knowing anyway for anything in the future.
https://www.rvtechmag.com/electrical/chapter3.php
Old 05-23-2021, 12:45 PM   #7
Appears to be random. I have both ACs on and residential fridge. I don’t even notice it until I see the alarm pop up on phone when I’m at campground.
Old 05-23-2021, 02:19 PM   #8
IMO your draw is not the issue. IMO you have a supply issue somewhere. The watchdog if similar to the progressive shows voltage before passing through the unit and will not let it pass if not within the parameters pre set. I would call the manufacturer tech support for a definite answer.
2016 Georgetown 328ts
2015 Fiat 500 Toad
db7512 is offline   Reply With Quote
Old 05-23-2021, 06:32 PM   #9
Thanks. Electrician is coming out. He thinks with the holiday weekend coming up ComEd is increasing the feed in anticipation of demand. He’s gonna check the outlet and give them a call.
power, voltage
