Originally Posted by Scrapper
Not if the fan does not spin fast enough to close the sail switch.
Correct, I've experienced several times where the furnace fan run and I had lights but the voltage was low enough the fan didn't run fast enough to make contact in the sail switch.
Back to the OP... you could have had two issues. Low battery and the propane things that have been discussed. You may need to address both.
