proper procedure to diagnose water heater
Hi , I am in the process of trying to revive my 2006 Rockwood HW 256. When I shut it down and covered it up 4 years ago everything worked including the hot water.
I am hooked up to the city water ( low pressure) and electricity. Both water lines seem fine into the sink. The gas flow seems fine ( everything works including the pilot on the back of the water heater igniter). So gas is at least getting to the igniter as pictured below.
I replaced the anode and at the time the ( old) water in the hot water heater flushed out. So I am assuming the water heater is/was empty. After running the city water through the sink for about 10 minutes, I then flipped the red switch to ignite the water heater. It temporarily ignited briefly once. Now it recycles and fails to ignite every 30 seconds or so. The red light flips on and off as well during this cycle.
I assume the one valve in the heater closet points to the cold flow so water will get in and fill the heater. What am I doing wrong? I can feel/ see a little bit of water flowing into the cold, but the water heater seems blocked from receiving water. How do I know/check when the hot water heater is full? Is it not being full the cause of it not igniting? Thanks!
