Originally Posted by loyda
We just bought a 2022 GT 36K7. As I drove home the radio was losing reception. Can only pick up 1 or 2 stations at home town, our other vehicles including our older motor home pick up 30 or 40 stations. There doesn’t seem to be an outside antenna only one I see is for XM radio. Any ideas would help, don’t really want to take back to dealer
Are you able to see, access the back of the radio?
If yes, use a wire coat hanger in the antenna jack to verify you can receive more stations than you do now. You may need to disconnect the current antenna for XM service.
Walmart has an inexpensive antenna that can replace that coat hanger. . . after all you'd want to do that . . . right
?? (BTW it was all the rage when I was a teenager. . .
Good luck . . . hope the new stations include your favourites!!
