06-29-2020, 11:11 PM
Radio Draining Battery (Furrion DV7200)
I've noticed that my Furrion DV7200 is not completely powered off, but in standby mode. Is there a way to completely power it off? Even in standby mode, I would think that it would drain the battery over the winter. Unless (RV newbie here) I'm supposed be disconnecting the batteries if my pop-up sits for longer than a month with no use?
Thanks!
06-29-2020, 11:28 PM
Install a battery disconnect switch on the battery.
06-30-2020, 10:42 AM
ditto on what bikendan said! and i'll be there are still other devices that create a parasitic drain on the batteries.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
06-30-2020, 10:49 AM
Insert witty title here
I remove my batteries for the winter but during the summer, I keep my camper plugged in at the house.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
06-30-2020, 01:00 PM
Radio battery drain
Just pull the fuse that is what I do on mine
06-30-2020, 01:04 PM
If I didn't keep mine plugged up year round I would install something. I considered a switch on the radio for that reason.
2017 Puma 297RLSS
06-30-2020, 02:11 PM
But if they install a battery disconnect switch, it'll stop the other parasitic power drains, like the CO monitor.
06-30-2020, 02:15 PM
I installed a switch that kills all power to the stereo for when we're boondocking -
06-30-2020, 10:16 PM
I installed a battery disconnect switch that disconnects Everything except the landing gear. I can hitch and unhitch it without having to connect the battery.
Prior to that I simply pulled the Negative battery cable from the battery....when I did that, Nothing was a drain on the system.
I still have my battery connected with a stainless hex nut on the Pos post and a wing nut on the Neg post for easy disconnect.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
07-01-2020, 10:18 AM
Battery Drainage
Yes, the only way to save the batteries during storage is to completely disconnect them from the RV circuitry and a battery disconnect switch is more convenient than disconnecting the battery cable. I put the switch in the negative line going to the RV frame and the batteries don't drain anymore.
07-01-2020, 10:52 AM
Any item that can be operated by a remote will have a parasitic power drain and it needs to listen for a command from the remote. Battery disconnect switch or add an on/off switch in the radio circuit next to the radio.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
