Range Hood and Kitchen Lights
I have a 2014 FR3 and the range hood fan quit on me. I bought and tried to replace the range hood fan/light unit thinking it was the fan motor that quit. When I took out the old range hood to check the wiring I lost the range hood light AND the lights over the sink. They all run on 12VDC. It seems like a blown fuse maybe? It seems like the lights over the sink are in line with the range hood. When I installed the new range hood it does not work either and I get no reading on the multimeter on the wires coming from the wall that connect to the range hood assembly. I checked the fuses in the battery control box and in line fuses in same area and they are all good. Does anyone know where there might be other fuses I can check? Or what may be causing this? All other 12VDC systems are operating. Thanks!
