Old 05-21-2024, 06:28 PM   #1
Range Hood Bulb
Hi,
The range hood bulb for our Forest River Salem 27RKSS has burnt out. I've never seen a bulb like this. I believe its some type of halogen. See attached picture. Anybody have an idea what it is?
Thanks.
Brad
Name:	range hood bulb.jpg
braberley is offline   Reply With Quote
Old 05-21-2024, 08:11 PM   #2
Originally Posted by braberley View Post
Hi,
Thanks.
Brad
Take it to your local auto parts store. That style lamp is used in many vehicle ceiling or dome lights.
I replaced ours with an LED unit. In fact, I replaced ALL of our bulbs with LED units. To wit, all 14 of our LED lamps on at the same time will pull the same amount of amps as that one incandescent bulb from the range hood.
Bob
P.S. - from your picture, it does not look as if the bulb is defective. However, I do see that one of the contact pins on the base is seriously misaligned.
Bob K4TAX is offline   Reply With Quote
Old 05-21-2024, 09:44 PM   #3
Here's a good LED bulb for the range hood. Replaced mine with one like this 3 years ago and as said earlier, much mess current draw from batteries and in my cas, a lot more light where I need it.https://www.etrailer.com/Vehicle-Lig...4aAuqTEALw_wcB
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 05-21-2024, 09:52 PM   #4
https://www.amazon.com/Camco-54766-M...s%2C166&sr=8-3
Capacitor is offline   Reply With Quote
Old 05-22-2024, 07:36 PM   #5
The one in the photos is an LED. same answer though. Stop at an auto parts store
MGD1961 is offline   Reply With Quote
Old 05-22-2024, 07:40 PM   #6
I digress. That could be a reflection in the photo that I’m seeing. Still the same answer. Looks like a number 194.
Old 05-23-2024, 09:42 AM   #7
My wife said it was burnt out, its possible there may be another issue, will check it out. Thanks for all the replies!
Old 05-23-2024, 10:13 AM   #8
D W
D W's Avatar
Hi,
Thanks.
Brad
Mine was equipped with a 922 instead of a 912. The 922 is a higher wattage than the 912 and it started to melt the plastic cover. My dealer gave me a new cover and a 912 bulb. I decided to replace the bulb with an LED equivalent because the 912 wasn't that bright.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 05-23-2024, 10:16 AM   #9
RV There Yet?
IsleDog's Avatar
these bulbs are generally referred to as T10 bulbs (base size). the number, 912 or 194 is for the wattage. you can switch this over to an LED bulb for less power draw if that is a concern for you. just pick the bulb shape you think will work best.
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
