Old 06-16-2017, 02:07 PM   #1
Windjammingnc's Avatar
Range Hood Fuse
We are camping in our new Windjammer and last night the fan and light in the range hood quit working.
I checked all the power center fuses and they are okay. I see mention of a fuse rating on a sticker on the range hood but can't see anything obvious where it may be located.
There wasn't a manual in our trailer packet either.
Anybody dealt with that in theirs?
Paul and Angela
Raleigh, NC
2018 Windjammer 3008w
Windjammingnc is offline   Reply With Quote
Old 06-16-2017, 02:08 PM   #2
A32Deuce's Avatar
Any panels to remove inside the hood?
A32Deuce is offline   Reply With Quote
Old 06-17-2017, 10:58 AM   #3
There was a panel between the fan housing and switches that was easily removed but no fuses. The fan housing looks like a much more complicated disassembly.
Paul and Angela
Raleigh, NC
Old 06-17-2017, 11:27 AM   #4
The motor prob has a built in fusable link. Fix is to replace the motor. When doing so, improve the cooling by making sure the mounting bracket is not blocking air flow. I drilled holes in my particular bracket since the bracket blocked all air flow from front of motor.
Motor was <10 on amazon...
Dp26 is offline   Reply With Quote
Old 06-18-2017, 04:36 PM   #5
How would a fusible link in the Motor affect the lamp in the hood as well? Hoping to get an answer fron thr dealer before I start tearing screws out, etc
Paul and Angela
Raleigh, NC
Old 06-18-2017, 07:52 PM   #6
If the motor was overheating, tje extra draw or the power at link blow could have burnt the bulb. At least in my unit, the bulb is a small automotive bulb. My bulb went out first.
Old 06-18-2017, 08:07 PM   #7
The bulb is okay. I checked it with an ohmmeter...
Paul and Angela
Raleigh, NC
Old 06-18-2017, 08:38 PM   #8
I believe (can't prove) that the wiring probably goes up into the small space between the bottom of the cabinet above the range hood and "floor" inside the cabinet. I know some folks have pried up the inside "floor" of these cabinets and accessed wires in there. I know my control panel wiring is between the cabinet bottom and the cabinet floor of the cabinets over my dinette. So your fuse MAY be in there.
2011 Traverse LT, 3.6L, FWD
fuse
