09-03-2022, 04:13 PM
Refrig not working.
2018 sabre 30 RLT. Hooked to shore power. Checked that circuit breaker is on and fuse is good. Frig. shows no signs of life. Help please
09-03-2022, 04:26 PM
Do you mind telling potential helpers which company made your refrigerator and maybe a model number?
09-03-2022, 04:36 PM
It's a Haier commercial frig. French doors. Manual says it is model HRF15N3
09-03-2022, 04:42 PM
From previous I know you have a res fridge. When you say breaker are you speaking of the breaker labeled fridge/inverter? Have you reset it by turning completely off and then back on?
Go look at the inverter. Is there a green light? This indicates it sees shore power.
Did this just happen or are you returning and setting up?
09-03-2022, 04:58 PM
It's the breaker in the breaker box labeled Frig. Yes I have turn breaker off and back on. Yes the inverter light is green. One thing have not done is unplug from outlet and plugged back in.
09-03-2022, 05:06 PM
Are you just returning or has it just stopped working?
There is a fuse on the inverter to protect the AC out. I think it is on the back. Check that fuse. You should be able to get to it from the front basement.
09-03-2022, 05:21 PM
Does the inverter have a gfci receptacle that you plug the refrigerator into. Have you reset it? What make model inverter? Can you plug something like a light or radio into the inverter to confirm that it is actually outputting power?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
09-03-2022, 05:35 PM
The fig is plugged into the outlet. I did not have my meter with me to check the outlet for voltage.
09-03-2022, 05:38 PM
Thanks for all your inputs. The 5er is in storage and it's raining here in FL. I will go after the rain to do some more investigating that was recommended.
09-04-2022, 09:03 AM
Well guys I have checked everything that was suggested expect the inverter. Will be climbing into the basement today. All gfci have been checked. The outlet for the frig is 125 volts. Can you tell what the picture is?
09-04-2022, 09:08 AM
Can I hook refig power cord to extension cord and run to power outlet separate from the 5er to see if frig will start?
09-04-2022, 09:51 AM
certainly!
09-04-2022, 10:01 AM
Well guys I have checked everything that was suggested expect the inverter. Will be climbing into the basement today. All gfci have been checked. The outlet for the frig is 125 volts. Can you tell what the picture is? Attachment 278734
You say the outlet for the fridge is 125 vac…. Seems like fridge is not working…
09-04-2022, 01:17 PM
Well after much trouble shooting I have determined that the frig has gone to its grave. It's Harier 15 cu. ft. Any suggestions on a replacement with out breaking the bank. Oh by the way this model has been discontinued.
09-04-2022, 01:23 PM
It maybe discontinued but parts should still be available . most likely it's a pc board since it seems power is off . i would do a search of model# and serial # for the pc power board
09-04-2022, 01:48 PM
Does it look like this? https://www.lowes.com/pd/Haier-15-cu...B&gclsrc=aw.ds
09-04-2022, 01:50 PM
09-04-2022, 02:04 PM
You are on your own.
Assuming it is the bottom freezer and both areas do not work I would assume controls. Not compressor.
There might be a glass fuse on the circuit board!
Getting to it should be possible.
Today, most refrigerators are much the same. Quality starts at big bucks! maybe 5X or more.
09-04-2022, 03:14 PM
Originally Posted by dalford
It's the 2nd one you post from Best Buy
09-04-2022, 03:18 PM
You said they were discontinued? Seems like you can get one. Google that model number. They can be purchased cheaper than BB prices….
