Originally Posted by Aspendog
We had the same issue. Turns out the frig electric plug fell out of the receptacle. The recep is located behind a panel under the frig that had to be removed. Who would install an electrical receptacle facing down so the plug can fall out?
If the plug fell out all on it's own you need to replace the receptacle. Tension is required on the plug blades not just to retain the plug but to assure good electrical contact. If the receptacle had enough "tension" plug wouldn't just fall out.
BTW installing them like this is done all the time, especially for garage door openers.
Loose receptacles can lead to appliance failure (low voltage) or in worst case, fires.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
