FYI, I found so far a couple posts all about this common problem… one in 2012, another more recent:
https://www.forestriverforums.com/fo...off-24973.html (shows the waxed paper / slide double sided tape, trick)
https://www.forestriverforums.com/fo...-179987-2.html
Same problem with us too, in 2021 ! Evidently, the problem has mutated from the original strain of oak panels falling, to the variant strain of Stainless panels. ;-)
We have a 2019 GeoPro G19FD that we bought new a few years ago, door panel started falling down last Fall. But panel is a 1/4" brushed stainless looking linoleum (I think). Luckily, no broken toes yet.
Funny thing is this, I found 2 plastic plugs on the floor and saved them.... found 1 about 1 month after the first on another trip. I was about to post both questions, first about the panel, and second, what these 2 plugs may have came from, ... come to read they are one in the same issue !
If anyone reading this has done the double sided tape fix, please describe if it was difficult to slide/reposition the panel back on with the tape and getting it aligned correctly?. (This is described in the old post above with all the waxed paper; I'm sure that works);
And what's best?: put the old same plugs back in, if the holes are not cracked ? Use SS 3/4" flathead screws ? Use the Liquid nails, Lexall? or use gorilla double stick tape?
That's all. Thanks ahead of time, if you can give any advice, please. Sorry, I cant post a pic of the door, trailer is not home now. I attached the Dometic diagrams and part #'s.
