Originally Posted by letup27
Can I run my Dometic refrigerator on propane only (rm2351). I dont want to supply ac when inverter is active. I was thinking about unplugging it. I can't kill the breaker because theres outlets on the breaker also.
According to the manual your model has two buttons on the front control "panel" One turns it on or off. Second one will place it in "Auto" mode which will switch to AC if plugged in (or inverter on if a whole house inverter). When you pres on the switch and release so it's OUT, the unit will run on gas only. The "Auto" light will go out and as long as the "Check" light is not on it's cooling with propane.
Here's the manual in case your's is unavailable:
https://www.dometic.com/assets/47/45...5.pdf?att=true
FWIW, the heater in your unit is 175 watts and you really don't want that load on your battery (probably around 16 amp allowing for inverter inefficiency) if you don't need it.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
