Old 05-26-2024, 10:16 AM   #1
Refrigerator not cooling on shore power.
I have 2016 surveyor
When I have the propane on the fridge works in auto mode. I don't know if it's on gas or power. I have shore power plugged in and propane off. The fridge is not running. I check fuses and GFI. All good. What else could be wrong.
Dometic dm2652rbfx
markus742 is offline   Reply With Quote
Old 05-26-2024, 10:41 AM   #2
bikendan's Avatar
Need make and model number of the fridge
Old 05-26-2024, 10:46 AM   #3
Dometic dm2652rbfx
Old 05-26-2024, 02:04 PM   #4
Check circuit breaker in breaker panel.
Open outside vent and see if outlet fridge is plugged into has power.
Twinboat is offline   Reply With Quote
Old 05-26-2024, 03:11 PM   #5
Checked outlet and reset GFI ,checked fuse and breaker , vent is clear. I did all that before coming here with questions. I turned the propane back on and after an hour I hear motors running on freezer and fridge now. Both cold now. Turning gas off to see if they keep running
Old 05-26-2024, 04:08 PM   #6
bikendan's Avatar
A 2-way absorption fridge doesn't have any motors.
Old 05-26-2024, 04:10 PM   #7
Sounds like the little 3/4 inch long 5 amp fuse under the black cover accessed from the outside that is blown.
2016 Sunseeker 3010 DS
If dogs don't go to heaven, when I die I want to go where they went.
Will Rogers
Sunseeker16 is offline   Reply With Quote
Old 05-26-2024, 06:04 PM   #8
It appears to working properly now. I have turned off propane several hours ago and it continues to get colder. Mabey i don't hear a motor but I hear something running periodically
cooling, power, refrigerator, shore power
