2021 XLR Nitro 28dk5. Went to start our refrigerator...and the outlet has no power to it. Checked the fuses and breakers, all good. Other outlets in the slide have power but the refrigerator has no power to it. Took the 2 screws out of the outlet and it won't budge.
Yes, it worked fine last year when we put it away. We traced it a little further. No power in the breaker box under the stairs, in the storage (refer & GP)
Not sure I understand. Has the problem been solved, or do you still have no power to the fridge?
CAMPING(n. CAM-ping) - When you walk the dog in your pajamas with a cup of coffee in one hand and a bag of dog poop in the other while striking up a conversation with total strangers.
I guess I’m confused. I am assuming we are talking about 120 volt circuits.
You first said the other outlets in the slide had power. I’m assuming these are 120 volt outlets. Just the refrigerator did not have 120 volt power. Again I am assuming. So for the other outlets in the slide to have 120 power there must be power to the breaker panel.
Yet now you say there is no power in the panel. Both of these statements cannot be true.
What make / model of inverter do you have? Some models have either a circuit breaker or giving receptacle that the output load (the refrigerator) plugs into. Have you checked them?
