Old 06-10-2018, 08:34 AM   #1
Ron045's Avatar
Refrigerator shelf collapses while traveling.
Our top shelf collapses everytime we travel. Does anyone else have this issue?
DW is currently using a bottle of BBQ sauce on the 2nd shelf for support, but it is a little too tall and is bending the shelf upward.
We need to find the right size condiment that can do the job[emoji3]
Ron
Ron & Family
2017 Shamrock 23IKSS (Traded)
No longer active with Forest River Forum.
Ron045 is offline   Reply With Quote
Old 06-10-2018, 08:37 AM   #2
What kind of refrigerator do you have
spock123 is offline   Reply With Quote
Old 06-10-2018, 08:43 AM   #3
Ron045's Avatar
All it says is Dometic.
Ron & Family
Old 06-10-2018, 08:55 AM   #4
I assume you have the shelf with the cut-out on the right side for the milk? If so that shelf is not made to hold a lot of weight. We put the light stuff on that shelf. If you have a trailer is the fridge to the front of the trailer or the rear? More info would help. Trailer type, fridge model>
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 06-10-2018, 01:14 PM   #5
BobHanke's Avatar
There should be clips like in the attached photo that keeps the shelves from shifting after they are installed. Should be available at or through most dealers and parts suppliers.
Name:	Dometic Ref Shelf Retainer.jpg
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
BobHanke is offline   Reply With Quote
Old 06-10-2018, 07:17 PM   #6
The shelf in our last one did all the time. Basically because it was poorly designed.
2017 Ford F350 LB SRW 4x4
2016 Cedar Creek Silverback 29RE
BigRockr is offline   Reply With Quote
Old 06-10-2018, 07:35 PM   #7
Open the outside access door and you should find the model number. Here's mine:
Name:	Fridge Model info vertical.jpg
2011 Traverse LT, 3.6L, FWD
Old 06-10-2018, 07:38 PM   #8
Just as confused as you
Scrapper's Avatar
If your shelves don't have the clips like BobHanke posted, get a piece of 1/4 inch inside diameter vinyl hose, cut 3/8 to 1/2 inch pieces then slice down one side so you can slip them over the shelf ends. If you need to place one on each end of the shelf.
Richard & Jill
Scrapper is offline   Reply With Quote
Old 06-11-2018, 11:25 PM   #9
Ron045's Avatar
We have the DMR702. I finally got a chance to pull the manual and I see the clips. Ours did not have any on any shelf. I will have to ask the dealer about it.
Thanks all for the help. For the moment, the BBQ bottle is doing it's job.
Ron
Ron & Family
refrigerator, travel
