03-07-2020, 06:19 PM
Refrigerator storage
Quick question. When storing your RV, Do you close up your refrigerator or chock the doors open a bit to prevent any smells or damage the inside.
We live in the desert of Phoenix Arizona and when storing our RV in the summer for a few weeks we chock the doors open.
If I forget to do this for a few weeks, am I gonna regret it?
What do y'all do? Thoughts?
Thanks,
Jim
03-07-2020, 06:33 PM
I think that if you experience warm temps then shut the frig off without letting it dry out you would be creating a mold generator.
Charlie & Cindy
2022 Duramax 3500 cc sb
2017 Wildcat 32 WB
03-07-2020, 07:37 PM
GLCM Warrior
We prop our refrigerator doors open whenever we aren't using the refrigerators (inside and outside). We just have to remember to close the inside fridge door before towing to/from the storage lot or the door flops open and bangs into things.
I think if you don't prop them open the fridge will smell bad after a few days...or, at least ours do.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
03-07-2020, 07:58 PM
Definitely prop it open with something. We use the Camco fridge door prop. Works well for us.
Just make sure you close and lock the doors before travelling.
2019 Heritage Glen LTZ 272RL
2018 Ram 2500 CTD
03-07-2020, 08:03 PM
If you look closely at the latch, many of the refrigerators have a pin that when extended will hold the door open.
And yes you should leave it cracked when not in use.
03-07-2020, 11:08 PM
Prop it open with the blue clips that Dometic provides. They fit in the door latches.
03-08-2020, 12:10 AM
03-08-2020, 12:40 AM
You're probably going to regret it. Not chocking the doors open will probably result in a moldy refrigerator.
One of the last things we do before storing is chock the door open. That way it doesn't accidentally get closed as we unpack the rig.
2015 Dynamax REV 24TB class C
03-08-2020, 12:54 AM
Go open them...you will have a mess on your hands otherwise. How much depends on temps when you last closed it and temps outside.
03-08-2020, 01:29 AM
Hi neighbor!
Thanks,
Jim
Jim,
(we're in Mesa)
The three and a half seconds it takes to make sure the door stays cracked open is well worth the effort.
Although we've never left ours closed, so I can't speak to any consequences, what harm could possibly be done by wedging it open? (unless of course, you're storing it on-site and plugged into shore power)
2012 Ram Laramie 2500 4x4 CC SB Cummins
2016 Flagstaff 8528RKWS
Patrick (order taker), Barbara (order giver) & Jasper (Dutch Shepherd) and now Jade (Boxer/Lab/Pointer hybrid) aka PB&JJ
03-08-2020, 08:12 AM
Thanks all for your response. I am aware that leaving the fridge door closed could be bad and I do leave it open. I have the plastic chocks that do the refrigerator and freezer doors both at once.
Only reason I ask is that the storage area moved my RV once without telling me. No damage, but I was asking in case they closed accidently and I was not made aware.
I asked the manager to let me know if he needed to move it and I would gladly visit and take care of things.
Thanks again all for your kind thoughts.
Jim
03-08-2020, 11:29 PM
IF the refrigerator has been open and has had a chance to dry out, you should be ok. If there is moisture in the refrigerator from the freezer defrosting, etc., you do run the risk of having mold grow in there. Our door got closed before we had a chance to clean it and even though it's a small fridge, cleaning the mold was not fun.
03-09-2020, 10:37 PM
When we get home I typically unload the fridge, turn it off, prop the doors open then mop up the water from the defrost. I then leave the doors propped open for several days to let everything dry. After that, close up the fridge and then close up the trailer ‘til next time.
