Originally Posted by TSman
Ok, I lost a lot of propane and then found a leak. Soapy water on regulator confirm the regulator is bad. The popping noise when turning on or off is apparently a sign of a bad regulator. Replaced it and all is good.
Glad you found the issue.
i had the same problem on a SOB (some other brand) and it turned out to be the regulator as well. I had trouble with the water heater and the furnace lighting too.
On mine, if I lit all three stove burners along with the oven, the stove burners would almost go out when the refrigerator, furnace or water heater tried to light.
