Old 06-12-2018, 07:56 PM   #1
Question Remove speaker
I’m the owner of a sunseeker 2500ts 2018,
How can I remove my speaker from my ceiling?
FrancisD is offline   Reply With Quote
Old 06-12-2018, 08:13 PM   #2
Most likely if the grill is perforated metal you will need to remove the grill first. You will need to use a small diameter pick in the holes to work it off by going around the perimeter until you can pull it loose from the speaker frame. Once the grill is off there will be 3 or 4 screws that will loosen the clips that hold the speaker assembly in place.
2021 Newmar Baystar 3401
2019 Jeep Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
Steve-W is offline   Reply With Quote
Old 06-12-2018, 09:08 PM   #3
Talking remove speaker
Thank you !
