Old 06-13-2021, 07:22 AM   #1
EcoBuckeye's Avatar
Replace Magic Chef Glass Top
Well I did it. In my tired state I started the kettle this morning on to of the glass top. After 20 minutes I was surprised it hadn't started boiling yet, so I lifted the kettle and the glass top beneath it exploded everywhere. And I exclaimed loudly, waking everyone else I was trying to let sleep.
So two hours later and a trip to Walmart for a Dust Devil and I nearly have all of the glass picked up and I'm looking for a replacement top but not finding many options. I have a Magic Chef MCFR21TTB which doesn't appear on the Magic Chef website, since I figure the FR makes it a Forest River product.
Any tips on finding the right part? Are the Furrion ranges the same?
2017 F-150 2.7L 4X4 Supercab
2021 Rockwood Roo 183
EAZ-Lift ReCurve R3 WDH
I've slept in 45 states and four provinces, but I have to start a new map for my camper!
EcoBuckeye is offline   Reply With Quote
Old 06-13-2021, 08:45 AM   #2
SeaDog's Avatar
I believe you are correct it designed for RV market only so not listed on the MC website. You might try giving MC a call be prepared for them to tell you that is only available thru the Mfg of the RV. If so get hold of FR they may sell it to you direct or say you have to go thru a dealer. Something you could do is measure the space and look for other options good luck
Retired Navy
2016 Flagstaff 26 FKWS
Old 06-13-2021, 09:04 AM   #3
D W
D W's Avatar
You are not the first one who has done that, and you won't be the last. There are numerous threads in this forum encountering the same situation as you. A lot of folks actually think it is a glass-top range. Last year my son purchased an SOB with the glass top. I warned him about the glass top. Wasn't long after that my DIL made the command decision to remove it. Incidentally, those glass tops have been known to shatter for no apparent reason, i.e. the glass has a stress defect.
You might inquire at a local glass shop to see if they can fabricate a piece of tempered glass for you, but often times custom glass work is expensive.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 06-13-2021, 09:06 AM   #4
Trailer Park Supervisor
NJKris's Avatar
If it becomes that difficult to find, I would consider cutting a board to fit the stove top, or something similar. Would certainly make kitchen chores easier, you could cut stuff on it, etc. My only concern would be accidentally igniting a burner, not likely, but then you have a flammable material over burners.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 06-13-2021, 01:08 PM   #5
Lorenc
My wife did the same thing in our 2020 Jayco. I got one from E Trailer. $160.00
2014 Forest River Surveyor Pilot
2019 F150 4x4 screw Lariat
lorenc is offline   Reply With Quote
Old 06-13-2021, 01:13 PM   #6
Witch Doctor's Avatar
try EBAY, I found one for my stove, I
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-17-2021, 01:21 PM   #7
rfifer
We feel your pain - our glass top shattered during a previous trip this year. Same thing, lit the burner without raising the glass top. Our stove is a Furrion for which we found a replacement top through eTrailer. Removing the shell of the old top took all of 20 seconds, and installing the new top about 20 seconds more. The replacement cost was about $150. As was said, you are not the first nor will you be the last.
Bob and Jan
Miami
Grey Wolf 26 DBH
TV F-150
rfifer is offline   Reply With Quote
Old 07-31-2021, 02:40 PM   #8
EcoBuckeye's Avatar
Update: the
Replacement Stainless Steel Top with Glass Cover for Furrion 2-in-1 Range Oven, although very very close, does not fit. I could probably make it fit since it's only off by 1/16" and needs mounting screw holes relocated, but I'd prefer to find one that fits without force or grinding. I'll contact the dealer next since I'm not finding a decent aftermarket part.
Old 08-01-2021, 08:01 AM   #9
Update: the
I just went through this when I needed to replace a single screw on my Magic Chef (MC) stovetop glass hinge. It is actually manufactured by Forest River (FR) under a licensing agreement with MC. I quick call to FR parts and I had the replacement in hand!
Cheers!
CivEngPE is offline   Reply With Quote
Old 10-21-2021, 10:35 PM   #10
Ours shattered as well. 2021 Rockwood trailer. Model of stove is MCFR21TTB Magic Chef. Glass stove cover is not available online that I could find. I called dealer and gave him vin # and model he ordered and I received in 1 week. $111.00 + 20.65 freight. From invoice it looks like it is referenced as F100138904 Stove Cover. I searched online as well but it does not show other purchase options using this information. I think calling dealer parts department is easiest and quickest way to get replacement. Hope this assist you for this model, Happy travels!
raiderfn99 is offline   Reply With Quote
