Since I've owned my TT I have only used the outside refrigerator for storage, only rarely turning it on.
My inside refrigerator has more than enough refrigerator room for my needs but way too little freezer space.
I just ordered a small upright freezer that fits the outside kitchen space perfectly. Power consumption of .66 kwh per day so it won't be a major draw on my battery bank (200 ah Battleborns) while boondocking. After a week or so the food in the outside freezer will be depleted and i will then use frozen foods from the inside freezer section of refrigerator.
Only $168 on Amazon and a whole lot less than an equal sized 12 volt unit. I already have the inverter that can run it with ease.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
As for battery "power", I have a portable solar setup that will provide about twice the running wattage of the refrigerator and my usual practice is to run the generator about an hour in the AM and same in the evening. When I start it for the microwave I just let it run for an hour each time. Mostly to just recharge the generator's battery and take advantage of a "boost" to the main batteries.
The smallness of the inside freezer has curtailed a lot of my bringing along frozen meats, etc and often I have to drive 40-50 miles to a real grocery store.
Just curious if any others that like to boondock mostly have done the same.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
