08-15-2018, 01:19 PM
#41
[QUOTE=Admiral;1900924]Yes I can see wires going up thru floor where fridge is but I can see no outlet.
I think what some are trying to tell you is FORGET where the fridge is. Follow the wires, cable, "away from" the fridge to find where it plugs into.
KEY words are AWAY FROM
08-15-2018, 01:58 PM
#42
do you have an error code on your display?
08-15-2018, 02:20 PM
#43
Back to basics
Getting back to basics, does the light in the refrig work?
08-15-2018, 03:12 PM
#44
Originally Posted by Admiral
Yes I can see wires going up thru floor where fridge is but I can see no outlet. Also wires from rear of inverter go to where it connects in cabinet next to fridge.
In an earlier post you said there were two connections connected together? Plug and a socket?
Those are the wires you need to investigate. The inverter does not run off of ac. It runs off your battery when ac goes away. The ac passes thru the inverter if you’re on shore power. When off shore power the ac is generated by the inverter and the shore power that was passing thru is now switched out (by relay but more likely an electronic switch) and the inverter ac is sent out.
If those wire run to the inverter then that is the ac to your fridge. The inverter could be bad and the relay/electronic switch is not allowing any ac thru.
08-15-2018, 03:15 PM
#45
The ac passing thru is also monitored by the inverter to know when the ac goes away.
08-15-2018, 03:33 PM
#46
two blue colored connectors, looks like wires come from inverter then plug into 2 other wires .........no socket or outlet.
08-15-2018, 03:35 PM
#47
I am plugged into 30 amp trailer plug also
08-15-2018, 03:36 PM
#48
So let me get this straight. The 2 blue wires from inverter does one have a female receptacle style connector and the other a plug type receptacle.
08-15-2018, 03:46 PM
#49
looks like from what i can see which is not real close, that the two wires from the inverter have blue connectors on the end, they plug into two wires that have white connectors. There is also two single coated electric wires around 10 gauage id guess capped off to two other wires like them. I wish i could get pics on here.
08-15-2018, 03:50 PM
#50
IMHO the two blue wires are the input and output to your inverter. I would think one blue wire would have a male connector. This would be the ac input to the inverter from the wire running from your inverter breaker. The other blue wire would have a female connector that would be the output from your inverter and the input to your fridge.
A pic would help...
08-15-2018, 03:56 PM
#51
How can i post a pic, it only gives me a link to a web address for pictures? Maybe i can add a video
#52
A pic would help...
Ok, after your last post forget what I said above...
But those wires have to be the input and output from the inverter..
You said you wished you could get pics on here, you can. Take a pic, scroll down when you reply to this post, select manage attachments, new window pops up, select choose file, one chose, select upload, wait for the status bar to finish then in top right corner chose close this windo.
08-15-2018, 04:06 PM
#53
See if this video uploads ok...
08-15-2018, 04:07 PM
#54
When you close the window the pic does not show in your reply message unless you preview it..
08-15-2018, 04:11 PM
#55
Ok i got it to start uploading video i just took............sorry to the other guys , i missed some of the posts. Hopefully the video will explain. Its at 60%
08-15-2018, 04:15 PM
#56
Yes i see your video
08-15-2018, 04:20 PM
#57
Ok, it will be a sec, for some reason it disappeared .........ill post when it is finished
08-15-2018, 04:25 PM
#58
ok video uploaded then sent me to a screen that said message- Please upload video in video field. Is that what is suppose to happen? Do they have to approve it or something?
08-15-2018, 04:30 PM
#59
Here, try this link ... I’ve never had any luck uploading videos to this forum..
https://www.dropbox.com/s/nen6fytm24...58-25.MP4?dl=0
08-15-2018, 04:33 PM
#60
No, I gave you instructions for uploading pics. When you scroll down before you get to manage attachment there will be a tab for uploading video...
Like I said, I’ve never had any luck but you may do better...
