Old 10-04-2018, 02:55 PM   #1
Residential refrigerator problem
My residential refrigerator compressor went out I have a fr rk27ss .it has a inverter could that be my problem?
92019875 is offline   Reply With Quote
Old 10-04-2018, 03:31 PM   #2
How do you know the compressor is Bad? What makes you think the inverter is the problem. Do you have 120 volts to the Fridge? A little more info would help.
Old 10-04-2018, 03:56 PM   #3
...far N Georgia!
formerFR's Avatar
need more info...
what makes you 'think' the fridge is bad/not working properly
what makes you 'think' it's the compressor
what makes you 'think' it has anything to do with an inverter
formerFR is offline   Reply With Quote
Old 10-04-2018, 03:59 PM   #4
Put hard start relay on ,work for three day ,repairman said must be compresser ,has 120V
Old 10-04-2018, 04:02 PM   #5
Head Rambler
My residential refrigerator compressor went out I have a FR RK27SS. It has a inverter could that be my problem?
That COULD be your problem, but it could also be something else.
If the fridge still has power, then the problem isn't the inverter.
If it doesn't have power then you could plug something (i.e. a 120 volt light or fan) into the inverter outlet, and if it comes on, the inverter is working and you need to look more toward the fridge.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 10-04-2018, 04:04 PM   #6
Thanks to all,,,need help on this one ::
Old 10-04-2018, 04:12 PM   #7
...far N Georgia!
formerFR's Avatar
it certainly could be the compressor, you just hope it isn't because that's a hard and expensive job. I'm with you on that, but, no, the inverter would have nothing to do with that, as I'm sure you have the same issues even on shore or gen power.
Old 10-04-2018, 04:55 PM   #8
bikendan's Avatar
Forest River is the corporate name, not the brand name.
What brand is the 27SSRK?
Equalizer WDH
Old 10-04-2018, 05:15 PM   #9
Retired JSO's Avatar
Why would you put a hard start relay on a refrigerator with an inverter already designed and installed by the manufacturer or is this a DIYS thing?
Retired JSO is offline   Reply With Quote
Old 10-04-2018, 05:19 PM   #10
Capt. Mike's Avatar
The 27SSRK is a Salem travel trailer.
What year is your trailer? Is it still under warranty?
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
It's not how old you are, it's how you are old.Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 10-07-2018, 08:17 PM   #11
2017 Salem rk27ss Forest River hard start relay put on by refrigerator repairman.he knows nothing about inverter when asked.So do I need a special refrigerator to work with a inverter .was going to replace it with a residential refrigerator from Lowe’s ,,,out of warranty now
Old 10-07-2018, 08:41 PM   #12
Chuck_S's Avatar
You need to isolate the problem and putting a 120vAC refrigerator in a 12vDC RV is complicated.
How is the refrigerator connected to the vehicle? Just a regular house type plug or is it hard wired to the inverter? If there's an outlet just run an extension cord from any good 120vAC outlet at your house and plug the refrigerator into it. If it works there's a problem somewhere between the RV's 12vDC system thru the inverter and to the outlet. If it doesn't work the problem is the refrigerator.
Find out the wattage the inverter can handle before looking at Lowes. These are called residential refrigerators but are very small for any real residence. My smallest house refrigerator draws about 750 watts. What's your RV refrigerator rating?
-- Chuck
Chuck_S is offline   Reply With Quote
Old 10-07-2018, 08:43 PM   #13
You're confused now I'm confused. There is no special refrigerator. An inverter will run any residential refrigerator. An inverter changes 12 volt DC to 120 volt AC. The inverter must be sized to the fridge.
Old 10-07-2018, 10:31 PM   #14
Just a regular type house plug,,,inverter is 1000watt ,,tryed other 120v outlet in house with extention cord frig not working
Old 10-08-2018, 07:31 AM   #15
Chuck_S's Avatar
OK, we know the problem is in the refrigerator.
Lowes and Home Depot have appliance sales all the time. If you don't need the refrigerator right now I'd wait for a sale. This will also give you time for exact measurements for a proper fit in the galley.
-- Chuck
Old 10-08-2018, 07:56 PM   #16
The next question is can you get the refrigerator out your door. A lot of residential refrigerator are installed before the sides are fastened to the frame
spock123 is offline   Reply With Quote
Old 10-09-2018, 07:09 AM   #17
Chuck_S's Avatar
That's a good question. Anyone know the width of a OE door? The 9.8 cf unit I just checked on line has the smallest measurement of 23" with the doors off. Removing the door from the frame will add an inch or so.
-- Chuck
Old 10-09-2018, 07:17 AM   #18
-- Chuck
Opening the door past 180 degrees should give you the full with without removing the door. If on a door closer preventing you from opening the door that far just remove the closer.
Old 10-09-2018, 03:13 PM   #19
Yes, have checked and it will pass through door, thanks again ,you guys are the best
refrigerator
