I checked the wires on the back of the dual USB port, and I can't see that they are disconnected. There's no screw connections on the back of the port, the 2 wires just go into the port. I removed the fuse box to look behind it for loose wires, but I couldn't see any loose wires. I'll check again tomorrow with a flashlight. Need a wiring diagram to see where the wires go... It worked fine the first several days, so it was originally hooked up.
