09-23-2021, 12:03 PM
Running ac on 110volts
Just a thought regarding running ac. What about starting generator to start the Ac then go to shore power 110 volts then turn off generator to run AC? Is that possible or not possible? I relies is proper to run AC on 30amp.
09-23-2021, 12:47 PM
Kanadian Kamper
Without knowing for sure…….I’m going to say you can’t go from the generator to shore power without a loss of power while the transfer takes place, and therefore the air conditioner, and anything else A.C. powered, would shut down.
I’ll bow to the experts.
Ken and Terry
09-23-2021, 12:48 PM
I have no idea what you are trying to accomplish but even if you can switch from gen to shore without disrupting the air. The air will still cycle in normal operation so starting on shore power.
What are you trying to do?
What do you have for shore power? What are the issues with it? If you have a choice you are almost always better off with shore power then a generator.
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
09-23-2021, 12:55 PM
Can you describe why you are trying to do this?
Might help understand what you want to accomplish.
Tow vehicle 2021 F-250
TT Apex 256BHS
09-23-2021, 01:19 PM
Always Learning
My guess is they're trying to plug into a 15amp household outlet and the in-rush of current for starting the compressor is tripping the breaker in the house.
OP's idea is to start-up the compressor on generator power and then let the A/C run using 15amp power from their house.
All that said, I know the automatic transfer switch can transfer hot loads like that. But I feel it's rough on them and prefer to shut things down before switching from one power source to another.
09-23-2021, 02:03 PM
Also that won't address the cycling, it would only handle the initial start
09-23-2021, 02:15 PM
Always Learning
I wondered about that as I wrote it but didn't want to speak out of turn.
09-24-2021, 09:07 AM
If this is the case, the best solution, IMHO, would be to install a soft start and ensure minimal voltage drop by using an adequate extension cord.
Cheers!
09-24-2021, 09:21 AM
My guess is they're trying to plug into a 15amp household outlet and the in- that said, I know the automatic transfer switch can transfer hot loads like that. But I feel it's rough on them and prefer to shut things down before switching from one power source to another.
The ATS must interrupt the AC power supply completely, even if only for a fraction of a second. This is to avoid connecting mismatched phases of AC which could cause an electrical explosion.
The only way to truly transfer AC electrical loads while hot is to monitor the phase rotations of both AC power sources and adjust one until it matches the other one, then the AC power sources could be combined. That's how inverter generator parallel connections work - one generator is the master and sets the phase rotation frequency and the parallel circuit adjusts the frequency of the second generator acting as slave until it matches the master and then combines the two.
09-24-2021, 09:52 AM
Kanadian Kamper
The OP hasn’t been back since originally posting.
Maybe it’s not that important after all.
Stand down and relax.
Ken and Terry
09-24-2021, 09:59 AM
You know people other then the OP can benefit from informational discussions. I can't count how many times I've read or seen something that did not apply to me then, but years later I found myself needing that useful information.
09-24-2021, 10:23 AM
Commercial Member
At 15 or even 20 amps not much can be used, the refer will take about 8 amps, and the a/c unit can use anywhere from 10-20 amps. So on a 15 amp power supply its already at the load threshold. Here is a little chart with wattage and amperages that might prove useful. I know Berkshires utilize the residential refrigerators, and that particular coach is happy using 50 amp, but can power some appliances while connected to 30A
09-24-2021, 10:32 AM
Always Learning
Cheers!
Actually, I think the best option would be to install a 30 or 50amp outlet.
Oh my...they have been off line for almost 24 hours. Call in the FBI...
2020 Flagstaff Micro Lite 25BRDS SOLD!
2024 Brinkley Z3100
2021 Ford F-350 XLT 6.7L Power Stroke
09-24-2021, 10:38 AM
No need to call the FBI, they are likely already monitoring anyway!
We do hope you found your answer here, though.
09-24-2021, 03:18 PM
Im just curious as to why you would want to do that
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
09-27-2021, 01:31 PM
[QUOTE=CivEngPE;2638656]If this is the case, the best solution, IMHO, would be to install a soft start and ensure minimal voltage drop by using an adequate extension cord.
If the intent of the OP is to stop a breaker from tripping, I agree fully with installing a soft start for more reasons than just that one.
It's also possible that the OP isn't using a dedicated breaker/outlet, such that other household electrical loads are sharing that breaker and even adding a soft start might not be a solution. If using a shared circuit, find one that has almost no other loads and try plugging into that one, with as heavy gage an extension cord as you can obtain.
2015 Wildcat Maxx 28' pushing a 2020 F350 6.7L
