Old 09-08-2024, 10:27 AM   #1
running frig while traveling
I would like to know how to run frig on travel days?
Tlwells is offline   Reply With Quote
Old 09-08-2024, 10:37 AM   #2
Not sure what fridge you have but there should be an auto setting of some sort. If so it should take cae of itself as long as the propane is left on.
2016 Sunseeker 3010 DS
If dogs don't go to heaven, when I die I want to go where they went.
Will Rogers
Sunseeker16 is offline   Reply With Quote
Old 09-08-2024, 10:41 AM   #3
I understand u r not supposed to run on gas on travel day. Mine has auto for gas or electric.
Old 09-08-2024, 10:47 AM   #4
Been doing it for over 30 years.
Will Rogers
Old 09-08-2024, 10:59 AM   #5
rracer5's Avatar
X2 Except if you travel through highway tunnels. You'll need to stop prior to and turn off the propane.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 09-08-2024, 12:01 PM   #6
Old guy having fun
Believer45's Avatar
We are assuming you have a propane/electric refrigerator. I have also been running mine while traveling for well over 30 years without issue. Turn it off for posted tunnels and when near fueling islands.
You should shut off any flame before you pull up to fuel pump area when fueling tow vehicle. Pull well away from the pumps before turning the fridge on again.
Dave / Belliever45
2013 Forest River Windjammer 3008W
2011 Ram 2500 crew cab short bed diesel 6 speed auto 3.73 gears RWD
Believer45 is offline   Reply With Quote
Old 09-08-2024, 12:21 PM   #7
Ours has the AUTO mode that switches from electric to LP. When we get to the campsite and have shore power available it switches back to electric. If there is no electric, it stays on LP.
So when pulling the trailer, it is automatically on LP.
Bob
Bob K4TAX is offline   Reply With Quote
Old 09-08-2024, 12:29 PM   #8
Mr. Dan's Avatar
Bob
Same here.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135/'23 = 78/'24 = 97; Booked for 2024 = 28
Old 09-08-2024, 04:03 PM   #9
bikendan's Avatar
RV owners have been running their fridges on propane over 75 years.
Where did you get the idea that you're not supposed to?
The only places that you aren't supposed to, are a few tunnels on the east coast and ferries.
There are some people that have a fear of the possibility of a fire so they don't. But it makes it difficult to keep a 2-way fridge coolness while traveling.
It appears that you have a motorhome so run the generator while traveling, if running it on propane bothers you.
Old 09-08-2024, 04:48 PM   #10
An open flame at a fueling/propane station seems totally legit.
2022 Cherokee Wolf Pup 18TO
2022 Dodge Ram 2500 6.4l Bighorn
Ballistic is offline   Reply With Quote
Old 09-08-2024, 05:02 PM   #11
6X me too.
Several earlier threads on this if you want extended reading.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
flyflotrtim is offline   Reply With Quote
Old 09-08-2024, 06:04 PM   #12
This is one of those horses (topics) that's been beaten to death and there's always those on both sides of the fence. There's days of prior post reading on this.
With that said, one must make the decision to do whatever one is comfortable with. With the exception of the aforementioned tunnels and ferries, there's no law prohibiting one from running a LP refrigerator while going down the highway.
There's also been great debate as to whether the burner flame located inside the rear of the refrigerator and inside the burner chamber is considered an "open flame."
I've yet to find anyone that has provided empirical evidence that R/Vs will/have burst into flames (while running the refrigerator on LP) any quicker when going down the highway -vs- sitting at a campsite.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=101
Old 09-08-2024, 07:43 PM   #13
I turn mine off for east coast tunnels and gas stops. It only takes a minute to open the door and turn off the fridge before fueling. My fridge is on the same side as my fuel fill so I always turn the fridge off and pull away from the pump before turning it on again.
I work a couple of days a month at a gas station and we have to watch safety videos annually. One of the required videos is of a travel trailer going up in flames at the pump. You can see thee flash at the refrigerator vent where the fire started. The truck, travel trailer, station awning, and a couple of other vehicles were destroyed.
BarabooBob is offline   Reply With Quote
Old 09-08-2024, 08:10 PM   #14
I always leave mine running on propane even at gas stations.
Just as a point of reference about the safety of having it on at a filling station, homes in the southern states typically put the gas fired water heater in the garage. Only building code requirement is it needs to be on a platform with a height of 18" or greater. Reason for the elevated platform, gasoline fumes are heavier than air so if the heaters flame is up at least 18" no worries.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 09-08-2024, 08:16 PM   #15
Mr. Dan's Avatar
That’s my operating procedure… and 18” is how high my home propane water heater is above my garage floor.
Old 09-08-2024, 10:47 PM   #16
I suppose this topic can be "picked and chosen" based on the relevant state code elevated water heaters are not to prevent the gas water heater from igniting fumes (although that is laughable), rather its to prevent the gas water heaters' pilot from being extinguished from flood waters and then cause secondary issues.
It's like a "chose your own adventure" based upon where you want to go.
Old 09-09-2024, 12:20 AM   #17
We also leave the propane on while traveling. We have the option of flipping a switch on the propane tank in the motorhome which makes it convenient when stopping at gas stations which is a whole lot easier than turning valves to close off the propane on a tt.
It's also possible to just leave the refrigerator off while traveling depending on how long the drive is. Food will usually keep for a few hours, but you could also put a bag of ice in the fridge and freezer if you're going to be driving longer.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 09-09-2024, 05:25 AM   #18
"On the road again"
rjshiflet's Avatar
We've always kept our propane refrigerators on AUTO during travel for over 20 years and never had an issue. Our current RV has a 12-volt refrigerator that runs off of our trailer battery and is re-charged by the truck as we travel. In addition, we have two more refrigerators (beverage cooler and outdoor kitchen fridge) that are 110 volt. We just have them cooled before heading out, then for our 5-6 hour travel days it says cool enough until we plug back in to shore power.
Robert & Estha Shiflet
Weatherford, TX
2023 Cruiser Aire CR28RK
(Former Forest River owners)
2022 Ford F250 Super Duty
rjshiflet is offline   Reply With Quote
Old 09-09-2024, 05:39 AM   #19
People aren’t actively fueling multiple vehicles in their home garage. This is a non-comparable in my opinion
MGD1961 is offline   Reply With Quote
Old 09-09-2024, 05:42 AM   #20
When we had a propane fridge we would turn it off with a couple bags of ice in it. Never had an issue with it getting to warm.
Then we would toss the ice in the beer cooler when we got there. Worked out great
travel
