01-25-2023, 09:21 PM
Satellite connection
Have read many questions being asked about satellite connections on many RV's but have found nothing on the connection on a 2015 Forest River Georgetown LX 360DSF. Have found a junction box over the passengers seat that has a TV/Cable/Sat selection switch with the connections wires out the back.
Search everywhere but have found not external connections. Understand that the SAT is probably prewired for a roof mounted antenna but were thought that there would be an external connection for the cable and SAT.
Anyone with this RV have knowledge they are willing to share.
Pretty much at the conclusion to just run a Ghost Flat wire coaxial through the window. The TV with plug is right at the window wit shelf to hold the receiver so problem would be easy to solve.
Tanks in Advance!!
01-25-2023, 11:12 PM
Moved thread from the Appliances and Electronics sub-forum to the Georgetown sub-forum since the OP is asking for model-specific information:
"Anyone with this RV have knowledge they are willing to share."
01-26-2023, 06:22 AM
This is supposed to be the GT360 coax interconnects.
01-26-2023, 08:41 AM
I think with those flat coax thru the window connectors, for some reason, you lose your HD. Not sure if this is true; seems like I read it here somewhere.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
01-26-2023, 09:09 AM
Retired Army MSG!
Tanks in Advance!!
I am not familiar with your particular rig but most of the time, external connections are located near your water hook up connections or near your shore power connection. I am assuming in your situation being a motorhome that you would find those connections inside one of your storage bays.
01-26-2023, 10:49 AM
The only dedicated sat dish (antenna) connection is the rooftop connection in the OP's GT360. The park cable port can be used for a carryout dish by removing the coax cable from the Movie Vision panel cable port and connecting it to the sat receiver. The sat receiver has an HDMI output for one TV direct feed for HD. If the sat receiver is a Dish Wally it does have an RF output and that can be fed to a modulator for coax conversion and its output connected to the Movie Vision panel cable port for distribution to all TV's for SD viewing. Just select "CABLE TV" on the panel and whichever channel is selected on the modulator on the TV's. By the way it matters not whether the antenna booster is ON or not if "CABLE TV" is selected on the Movie Vision panel.
01-26-2023, 10:55 AM
Don't know why shape would be an issue if it's RG6 coax (i.e. 75Ω).
01-26-2023, 11:13 AM
Originally Posted by bubbles
Don't know why shape would be an issue if it's RG6 coax.
X2
Most all the ones I've seen/used were HD/dish compatible.
01-26-2023, 04:59 PM
Not sure what, if any is the difference between a GT 360 and what I have is the LX 360 DSF. I assume there is as they have different names.
01-26-2023, 05:02 PM
Originally Posted by 5picker
X2
Thanks, that is precisely the one I ordered last night. Think it will be no brainer to just run it thru the window that is right at the TV and be able to use a short cable to go from there. Have not seen the receiver yet so not are if there is a HDMI port to the TV or not.
Thanks!!
01-26-2023, 05:12 PM
I believe what you have is a Georgetown360"XL"DS and the drawing would be applicable for at least the issue (sat antenna (dish) coax connection) in your post. Distribution throughout the coach may not be the same.
01-26-2023, 05:49 PM
Thanks!!
If it's a Dish Wally it has an HDMI output port (no coax output port) and RF composite (R/Y/W RCA) video output ports.
01-26-2023, 07:05 PM
I have a 2018 31L5 and found all the hookups in the center storage cabinet over the drivers seat. If yours is similar to mine there are 4 screws in the back panel that allow access to the splitter and satellite pre wire but there is no external hook up for satellite for mine either.
01-26-2023, 08:18 PM
Found the box that has the TV/Cable/Sat selectors. I'm referring to the outside connection points. I have looked but will again this weekend. I have been told by two different people that it could be in the water hook up bay. If not, I am satisfied to run one of the flat wire connections through the window. I can leave just enough outside, pinned down by the window so it won't vibrate and fly around and run it from there. Not really worried about a parks cable, as they are normally not that good anyway.
Thanks for the info! I'll get there yet!!
01-27-2023, 08:18 AM
There is only one coax input port and it is for park cable (can be configured for sat as previously posted). The only dedicated sat port is the prewire coax routed to the roof for a roof mounted sat antenna. Some GT's do have a coax output port (yours may have this) in a storage bin on the passenger side along with a 120Vac receptacle for an external TV. Don't know what the newer GT's have provided.
01-29-2023, 01:19 PM
Found the Park Cable connection in the electric bay.
Thinking that it will be very easy to just run the cable (flat one as mentioned above) thru window, already done, and the TV is right there with center to hold the receiver with electric plug also.
Now all I need is the dish! Lucked out as I will be able to just pay him the small monthly fee and use his account as they have Dish in their home so it just an add on to that.
01-29-2023, 04:12 PM
Just a word of caution so "him" doesn't get teed off. Wherever you go do not call Dish to have the local channels changed to your location. If you do "him" will lose his local home channels. You'll have to use the over the air antenna for the local channels (major networks) if you want and can receive them.
01-29-2023, 05:11 PM
Thanks but it is my brother in law and lives about 5 minutes away. So none of the Chanels will change. Thanks for the heads up tho!!
