10-04-2019, 07:08 AM
Screen Casting in RV?
Anyone using a wireless display adapter (miracast)... like the Screenbeam or others.. to mirror movies, etc from your phone or tablet to the television in your RV? What are you using? Are you happy with how it works?
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
10-04-2019, 07:25 AM
Chrome cast need internet. I use my samsung tv and stream from my samsung phone. Easiest way without needing internet.
10-04-2019, 07:40 AM
Hi,
I set up my smartphone hotspot to get the necessary network, and then use it to Chromecast from my tablet to my TV. Easy and quick...
FWIW.
Rich Phillips
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
10-04-2019, 07:50 AM
Part-Time Campground Host
Originally Posted by richp
Hi,
FWIW.
Rich Phillips
X2.......
Craig & Cath
Days camped since 2015(retirement): 1689
10-04-2019, 01:01 PM
I use a Chromecast adapter, with my Vizio.
My Samsung doesn't need an adapter.
Use phone as hotspot.
Dish Anywhere app to watch everything from our home DVR.
Use Chromecast for Amazon Prime channels.
10-04-2019, 01:17 PM
Casting to tv
We use a usb-c to HDMI adapter. Download movies to Netflix and mirror you phone screen to the tv. Zero data or WiFi required.
10-04-2019, 01:35 PM
I use my Samsung phone to a Roku Streaming Stick.
Ray
2020 Georgetown GT5 34H5
10-04-2019, 05:52 PM
I use a Screen Beam mini 2 and stream from my laptop. Download movies from Netflix at home before the trip. Needs no internet.
Hadn't thought about the fact that I just replaced my Jensen TV with a 32" Samsung and have a Samsung phone, hmmm. Have to investigate if I can stream directly from my phone.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Lab Buddy Biscuit Eater
USN-RET/DOD-RET
10-04-2019, 06:19 PM
It's pretty easy. You just pull down the upper bar, on the phone, and swipe to the second page where you'll see the Smart View icon. Click that and then activate the tv's Mirror Image feature. They should pair up.
You should be able to find a video on the process.
10-04-2019, 06:27 PM
Ray
^^^ This ^^^
We have a Samsung Galaxy S2 tablet that we screencast to our Roku. The S2 uses about a quarter of the bandwidth that the Roku uses (i.e. Netflix, Amazon Prime apps), and the picture looks great.
2020 Riverstone 39FK
2016 Ford F-350 DRW 6.7L PowerStroke Lariat
10-04-2019, 06:42 PM
It's called Smart View on my S9+ and just Screen Mirroring on my 2013 Samsung TV.
Ray
10-04-2019, 07:13 PM
Thanks, I will check that out tonight
2016 Jeep Willys JK
USN-RET/DOD-RET
10-04-2019, 07:28 PM
Ray
Smart view seems to imply it will work with chromecast? anyone know if there are alternatives for non Samsung tvs.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Any problems with losing the connection? Or the audio getting out of sync? Would you say it's pretty reliable?
10-04-2019, 07:37 PM
I do no issues as long as its a smart tv
10-04-2019, 07:39 PM
Hi,
As to TVs that work with Chromecast, mine is the cheap Jensen that came with the trailer. It has an HDMI port for the Chromecast gizmo to plug into, which I think is the key.
Don't know about the Amazon Firestick and other technologies. But Chromecast needs to be able to talk to your computer through a network (in my case through the phone's hotspot). Whether a campground wifi would suffice for this purpose may be doubtful, since you are constantly moving a fair amount of data to maintain the TV image.
FWIW.
Rich Phillips
Rich Phillips
10-05-2019, 10:18 AM
Just use an HDMI cable from phone to TV, or laptop to TV.
I have a Chromecast I don't use, didn't realize I needed a separate wifi signal to cast from the phone (which has it's own data plan).
Carla VE5YAK
wife to David, mom to the 3Ms
Saskatchewan, Canada
2006 Dodge RAM 2500 TRX4 Cummins
2011 Cedar Creek Silverback 35K
10-05-2019, 10:29 AM
Hi,
Maybe I wasn't clear.
I set up the network on my phone. The device that is doing the casting and the Chromecast device itself (connected to the TV by HDMI) talk to that network.
Hope this helps.
Rich
Rich Phillips
10-05-2019, 10:42 AM
Hi,
Hope this helps.
Rich
I understand how the chromecast works (now that I have it and tried it). I found using the hdmi cables to be much simpler solution.
No smart TVs in the house/trailer so no casting without a device. And when my data plan at the trailer is my only option, I can't cast with CC from the phone. It needs a separate signal (which I find dumb).
Carla VE5YAK
10-05-2019, 10:45 AM
I'm either using HDMI to stream from my laptop to TV or Fire Stick and using my phone as a hot spot if no Campground wifi is available...
If you're going the Fire Stick route, I would suggest you set it up the Fire Stick at home first... The reason for this is if you want to use some of the Fire Stick apps like FOX or NBC, HBO, Showtime etc, you need to set them up and it is somewhat time consuming.. The apps will ask you to select your TV provider (Comcast, Dish, Verizon etc) and you need to key in your user name a password from that provider and you'll be on faster wifi at home.
Lastly, using your phone as a hot spot does chew up your data quickly so make sure you have enough data on your plan... And even if your plan is unlimited, most wireless providers will throttle you after you've used X amount of data and the at throttle speeds, the Fire Stick is useless.
Gerry Z
2018 Forest River Heritage Glen 272RL
2018 Ford F150 Lariat 3.5 Ecoboost Max Trailer Package
Curt Trutrack WDH
HD Roadmaster Active Suspension
3200 Firman Generator/Inverter
