04-14-2021, 09:33 AM
Searching for a replacement AC capacitor
I have an old Carrier RV AC on my pop-up with a discontinued SAMWHA capacitor. (picture attached.) I can't seem to find a replacement capacitor on-line anywhere, either from the US SAMWHA distributor, several on-line electronics supply stores, Carrier itself (they are out of the RV business it seems), a major RV dealership network, and a local HVAC electrician with links to the local distributors. Any ideas on how to find a compatible capacitor (12/40 microFarads; 370VAC?
04-14-2021, 09:50 AM
you can substitute any cap. with at least that voltage and capacitance and larger. It won't hurt it to have a bit more. Limiting factor is where it's mounted but you can move it easily enough.
04-14-2021, 09:58 AM
Grainger is a great source for items like this. A quick online search on their website will also tell you if a local branch near you has the item in stock.
https://www.grainger.com/content/general-catalog
04-14-2021, 10:11 AM
04-14-2021, 10:31 AM
04-14-2021, 10:33 AM
Originally Posted by bubbles
that one will not work, as the OP's capacitor has 2 circuits in one can, a 40uf and a 10uf. its a start/run capacitor, not just a start cap.
04-14-2021, 11:00 AM
Potential Solution found
Spoke with Grainger - as no one manufactures a single dual run with the correct farad ratings, they suggested using two - each with the correct microfarads - and splicing the commons together, which makes a lot of sense. I'll give it a try - the mounting should not bee too difficult as there is a lot of room in the compartment
04-14-2021, 11:03 AM
This is a very common solution as the "one piece" units are required for applications where there is no extra space.
04-14-2021, 11:20 AM
X2
2017 Chevy Silverado 1500 4wd
2019 Wildwood FSX 260 RT
2012 Harley Davidson Street Glide
2022 Yamaha Wolverine RMAX2 Sport
04-14-2021, 01:23 PM
Weekender
Originally Posted by Bogieboy
Bogieboy is correct. This is the direct replacement!
04-14-2021, 01:37 PM
Buy Two!!
04-14-2021, 01:48 PM
Thanks!
Thanks to all - I will try BogieBoy's direct replacement - I am assessing the slight difference in the fan motor's farad rating will not hinder operation. I wish I would have posted a few days ago - it would have saved me a lot of time and effort!
04-14-2021, 02:25 PM
I have a 45 / 5 if interested offer up https://offerup.com/item/949136985/d...8768/messages/
04-14-2021, 02:28 PM
Guess you're right. He would have to use his finger to get the fan running. Incidentally, 370 volt rating is just the minimum; anything higher voltage rating is OK.
04-14-2021, 02:33 PM
