06-30-2020, 09:01 PM
Slide out wiring retraction plastic bracket.
I just need to know where to order/get one of these... for a Rockwood M-2104s
20200630_203722 by rynegold, on Flickr
Somewhere along the 4k miles we traveled (actually the last 300) it has broker loose.
(1) What is this called?
(2) where can I get one? I assume it's a common item on slideouts.
Thanks and regards,
mitch
The other two pixs:
https://www.flickr.com/photos/190898...57714925360433
06-30-2020, 10:05 PM
May not be exactly what you want but it’s a place to start
Lippert Components Flex Guard Single Kit with Hardware
http://Lippert Components Flex Guard..._b0.-EbZP628GB
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
07-01-2020, 05:30 AM
Better Price and is what comes on the Rockwood, I replaced three of them in two years on my Rockwood. What breaks them is they staple them into the aluminum, I modified mine so they pivoted at both ends which stopped the breakage.
https://www.rvupgradestore.com/Lippe...DAF1498EAC3AAB
Retired 2020.
46 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
07-01-2020, 10:33 AM
Thanks to you both! I"m off to buy one.
regards, mitch
07-01-2020, 02:24 PM
Wire support
I have had to replace both on my Flagstaff. Make sure you match the pre-made curve, old VS new. The 1 st. one I had to replace was due to FR installing it backwards under warranty. Replace small head screws or staples when remounting. Use hex head self tapping sheet metal screws, 5/16" head. Add an additional screw where it mounts on the outside rail-make a "triangle" w/ the 3 screws. The wire straps crack and break at this spot, this larger head gives more surface contact area and better support. After replacing these on several trailers, more than once, this been the fix. It has held for 2 years.
It you have broken several wire straps,you may need to move screws to prevent too acute an angle on straps when you put slide in or out.
PS-I have learned to carry several of the "Plastic ball and elastic strap" tarp tie down to fix these wire straps when they break on a trip. I have saved myself and others w/ one or two of these straps and zip ties.
07-01-2020, 03:30 PM
Mine broke off at least I wasn't going down the road! I actually fixed it using a door hinge on it used pop rivets on the plastic end with washers for keeping the plastic from breaking again. it works better than original as the hinge has more support for the plastic and it gets less drop when extended.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
07-01-2020, 03:44 PM
Plastic
Great idea w/ hinge! I beat a gate hinge would work well. Much better idea and saves the $25 they get piece of plastic strip to replace. A lot of trailers use the same Lippert part.
07-01-2020, 06:39 PM
Replacement strap
Thanks and regards,
mitch
The other two pixs:
I replaced 2 of these straps. First one from Lippert. Price wasn’t bad, but shipping was $30. Went to Amazon for my 2nd one. Easy fix.
07-02-2020, 10:39 AM
These are terrible. Mine when putting in the slide out dropped down below the slide mechanism. It broke rubbing on the tire. It also rubbed through the slide out wiring. What I did was put a hinge where the break was. Also put a hinge on the outside spot on slide out but pointing more up.
Now each time I put in the slide I make sure it hasn't dropped below slide out mechanism. So far no more issues.
2017 Forest River Surveyor 251rks
2022 Chevy 3500HD High Country
07-02-2020, 11:15 AM
My silverback has a different size on each slide. They have both broken at the slideout connection. Replaced both with heavy duty fence gate hinges.
WyomingJack
2015 CC Silverback 29 RE
2014 GMC 2500 HD
