01-04-2021, 11:00 PM
Sliding drawer opens when traveling
The sliding drawer under the kitchen table in my 2608BS Rockwood comes open when traveling. The magnetic lock on the rail doesn't seem strong enough to hold it. Anyone found a better locking mechanism or rail system?
Wes
01-05-2021, 09:12 AM
welcome to the forum its a great place to get your questions answered. Im sure someone on the forum will chime in with a fix.
Retired Navy
2016 Flagstaff 26 FKWS
01-05-2021, 09:25 AM
Get some neodymium magnets. Pick ‘em strong enough and even you will find it hard to open drawer.
2019 Cherokee Grey Wolf 29TE
2018 Ford 150 SCAB STX 3.5 EB
01-05-2021, 09:36 AM
Is there room to install a mechanical catch?
Many folks have added something additional.
There are even posts about straps or bungies.
01-05-2021, 11:29 AM
Thanks for the advice - now I know what to look for!
01-05-2021, 12:51 PM
Trailer Park Supervisor
Originally Posted by Librarianocnj
Get some neodymium magnets. Pick ‘em strong enough and even you will find it hard to open drawer. ��
The way these things are built, you probably pull the whole front of the drawer off trying to open it, lol.
Yes, I drink the water!
01-05-2021, 01:17 PM
Either that or the weaker occupants won't be able to open it.
Those things are mega-strong. They'll hold onto that drawer more than a snapping turtle onto a toe!
John, KA6CHX
2018 FR Berkshire 39A
01-05-2021, 01:23 PM
Drawer Opens
Lots of things available to retain the drawers while traveling. I just bought some"Baby Locks" at the hardware store and installed them. Have used them for years. Cheap and effective.
01-05-2021, 05:00 PM
I've had this problem on a couple of items including a swing-out big-screen monitor which has gone thrashing back and forth on several trips. Bottom line, I add to whatever is already there, I don't replace it. So, where there was one hook or catch, there are now two. Lowes and Home Depot have a lot of things that will come close to matching the catch/hook/knob, etc. and even the color.
2018 Berkshire 38A
01-05-2021, 06:26 PM
I bought these from Walmart.com they work great.
Camp'N - 4 Pack - Push Catch - Latch - Grabber - Holder for RV Cabinet Doors with Mounting Hardware - 5 lbs Pull Force - Perfect for RV, Trailer, Camper, Motor Home, Cargo Trailer -
01-07-2021, 12:43 PM
Thanks to all for your input. Due to lack of space to add anything new, I've shimmed the rails a bit to make a tighter fit when the drawer rail engages the fixed rail in the box. It seems to be a bit tighter, we'll see if it works next trip. The root of the problem appears to be to be the cavity is too big for the drawer width with the installed rails.
01-07-2021, 01:15 PM
On my TT the drawers are "latched" in place when the front drops into kind of a locking position when fully closed. Have to lift and pull to open.
I had problems with one drawer sliding open during transit until I found it was being blocked from that final "drop" when fully closed. Both cleared some junk that was holding the drawer up and adjusted all the hardware on cabinet and drawer. Amazing how loose screws can get after close to 30,000 miles of highway and FS roads
01-07-2021, 01:25 PM
One thing that we have done in the past when we had this problem was use velcro. We got the long roll from Walmart (pretty much any store that sells that kind thing), its something like 60" of hook side and 60" of loop side. Take the drawer out, and screw the hook side (of the hook and loop) to the inside (it makes it the back of the cabinet front as you look at it). On the other side, screw the loop side (verify that when they are installed such that the hook side faces toward you, and the loop side faces away, or vice versa to ensure they will stick to each other). Cut it long enough that each strap overlaps about 2/3s of the drawer front. When you are traveling, just velcro across the drawer front. When you get to your destination, unhook the velcro, open the drawer, and tuck the straps into the opening, outside of the drawer, just dangling in the cabinet void. Quick install, doesnt leave anything permanent, and it only takes a second to strap/unstrap.
_________________________
2023 GMC Sierra 3500 Denali
2020 Cherokee Arctic Wolf 287BH
