Two 100 watt panels in full sun will cover basic trailer power: DC for propane fridge & water heater, LED lights, and occasional water pump usage, USB device charging, & efficient cooling fans.
Cloudy day or two, or shaded site, and you start falling behind.
We have had two trailers each with two 100 watt panels, and they will support the items above in full sun.
Your problems are the e-bike charging and the heater fan. 36V will require an inverter, and the furnace fan is a power hog. Run occasionally, or all night?
You did not mention if the TV was 12 or 120. At 120, you see the inverter losses add to the power budget. Same with inverter for computer charging.
2021 Isata 5 28ss 4x2 / 2020 JLU Rubicon
Prior: 2016 Lance 1995 / Ram 1500 Eco Diesel
2012 Lance 1575 / 2015 Jeep JKU Rubicon
