Old 06-25-2018, 02:32 PM   #1
Question Something is draining my battery when camper not in use
I am new to FR Forum and new to campers and camping. Something is slowly draining my battery when my 17 ft FR Coachman is parked and not in use. I have a sneaking suspicious it may be the Jensen radio/CD player as the light and clock are always on. Any help/advice will be appreciated!
ncstamos is offline   Reply With Quote
Old 06-25-2018, 02:36 PM   #2
Carknocker Family
Ida Ratherbe Camping's Avatar
That and you propane detectors and the list goes on. Either unhook battery, put a battery cut off switch on if you don't already have. Or leave it plugged in.
Ida Ratherbe Camping is offline   Reply With Quote
Old 06-25-2018, 02:36 PM   #3
and your propane detector and your tv antenna booster and several other things. Need to remove the negative on your battery cable or install a disconnect. Common issue with all/most rv's
Kimber45 is offline   Reply With Quote
Old 06-25-2018, 02:38 PM   #4
Flybob's Avatar
There are several things that will kill your battery over a week or so. The biggest is the CO/Propane detector followed by the DVD/Radio. If you are going to leave parked, add a battery disconnect switch or just disconnect the negative battery terminal
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-26-2018, 02:22 AM   #5
bikendan's Avatar
Some Dometic fridges have a climate control feature without a switch, that is a big battery drain when not plugged into shore power.
Equalizer WDH
Old 06-26-2018, 05:16 AM   #6
Oaklevel's Avatar
As others have mentioned this is normal. Many things can and will drain the battery. Best thing to do is add a battery disconnect or disconnect the battery when in storage.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 06-26-2018, 06:04 AM   #7
Prime Member
Just leave it plugged in while parked.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 06-26-2018, 02:33 PM   #8
Wolverine 1945's Avatar
Does your Coachman have a Battery Cut off switch ???
Wolverine 1945 is offline   Reply With Quote
Old 06-26-2018, 02:57 PM   #9
bikendan's Avatar
I'm assuming that, as it's a 17ft trailer, it's probably an entry level trailer which don't have factory battery disconnect switches.
The OP doesn't have the trailer model listed in their profile.
Equalizer WDH
Old 06-26-2018, 03:22 PM   #10
Bluepill's Avatar
My Jensen consumes some power even when it is turned off. I just remove the faceplate and store it to decrease the battery load. I only disconnect the battery when storing for more that a week, so that I have battery power for the electric brake breakaway system when towing.
Old 06-26-2018, 04:44 PM   #11
The other alternative is (if your unit and surrounding areas are completely secure) is to hook up a solar charger. You wouldn't need a big one for storage power.
yakmeat123 is offline   Reply With Quote
Old 06-26-2018, 08:18 PM   #12
camaraderie's Avatar
Get a 7 buck battery cut off switch at Walmart. Put it on your negative battery terminal and attach your negative battery wire to it. 5 minutes and problem solved.
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 06-27-2018, 05:06 AM   #13
Former Navy
Former Navy's Avatar
Battery draining while stored
Just remember to check your Battery Water level occasionally if you keep it plugged in while not being used. Best solution is the Battery Disconnect Switch in my opinion.
Former Navy is offline   Reply With Quote
Old 06-27-2018, 09:04 AM   #14
ANY those little lights will do it. The one that snags me sometimes is the antenna power button. You wouldn't,t think it would matter that much, but over time it does. If ya can,t turn the light off then flip a breaker or pull a fuse.
Philandterry is offline   Reply With Quote
Old 06-27-2018, 09:12 AM   #15
It's op ask a question and disappeared ???
Our TV would be very easy to unplug,,, in fact I had to replace the fuse last week !!!
battery, camper, drain
