Old 03-29-2023, 10:23 AM   #1
Sound Problems in Lexington GTS 300SS
How do we get the surround sound to work?
The coach is wired for a Wine Gard but doesn't have one. The TV antenna doesn't appear to be connected either! I have a technical background but after a lot of hours this has me stumped. Help!
Twyggers is offline   Reply With Quote
Old 03-29-2023, 10:53 AM   #2
Kanadian Kamper
kenandterry's Avatar
We need your help first….
Guessing you’re not the original owner…..
1. GTS300SS. What year?
2. What make and model of stereo connected to surround sound speakers?
Pictures always help.
3. Describe how you know it’s wired for Wine Gard. Pictures help.
4. What brand of TV antenna? Booster switch plate button “ON”?
5. Have you tested the TV with coax connections inside your house?
Ken and Terry
kenandterry is online now   Reply With Quote
Old 03-29-2023, 12:27 PM   #3
300SS
its a 2007 on an E450 chassis
Concertons zx600, wont load disc
Antenna has no booster switch I can find. know it did have a wine Gard as there is the sat search switch etc in the cabinet as well as a couple of antenna cables
TV doesn't tune into another antenna so that is another problem. Just would like the surround sound to work!
Old 04-03-2023, 12:59 PM   #4
We have a Concerttone ZX690 so sounds similar. The Winegard antenna had a switch box that can direct things between 3 TVs as I understand it and seems to work that way. I loaded some pics- first and 2nd are the antenna signal splitter, then others are mods I did. It all used to be in right cabinet and TV was fixed. I moved it all into center after insulating in the front bubble (there was none) and mounted the TV on an extendable bracket that locks. Let me know if you need more and closer pictures and I can get some for you.
ID:	285449   Click image for larger version
ID:	285450   Click image for larger version
ID:	285451   Click image for larger version
ID:	285452   Click image for larger version
Danimal713 is offline   Reply With Quote
Old 04-03-2023, 01:26 PM   #5
bikendan's Avatar
Moved thread from the General Tech and Repair section to the Appliances and Electronics sub-forum.
Sent from my SM-G781U using Forest River Forums mobile app
gts, lexington
