07-02-2021, 11:07 AM
Source for older Dometic reefer parts?
Hello,
I have a Dometic refer model DM2652 (921144324) manufactured in 2009. The unit no longer switches to AC but only runs on propane. I’ve confirmed AC to the board but not on J7/J8 output to heater. This model uses a power board with integrated igniter. I can’t seem to find a source for a replacement board that has the igniter on the board. Any ideas, please?
07-02-2021, 11:12 AM
07-02-2021, 11:28 AM
please let us know if you have any luck with parts for that fridge
2014 Shamrock 183
07-03-2021, 12:09 PM
Two things
Originally Posted by LandNSea
Hello,
Did you check the AC fuse reached by removing the panel on the outside? I seem to recall one fuse for AC and one for DC, both the glass cartridge type.
If that's not it and you need the board, try some of the RV salvage yards. There are dozens of them. An internet search will get you going.
Larry
07-03-2021, 05:32 PM
Part found!
Hello FR friends, I found the needed power control board at Dyers Online and also at Amazon (of all things). The replacement part number is 3316348.900. It’s a direct replacement for the old board. Thanks for your earlier replies!
07-04-2021, 02:48 AM
Hello,
Dinosaur electronics, better product than factory boards
Dinosaur Electronics Home. High quality circuit boards for RV appliances.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
