Originally Posted by dalford
X2, I did this on out cooktop. I turned the back right way down but make sure you don’t turn it so far down that it is easily extinguished.
Also remember, your front burner is your hottest burner.
dalford wrote:
"...make sure you don’t turn it so far down that it is easily extinguished."
A good point, dalford -- it's a bit of a balancing act to adjust "perfectly" & important to be sure that turning to max low doesn't distinguish, but it is really simple and easy to do. Best I recall, it's taken every bit of 5 minutes on our last two RVs as well as our home kitchen stove. In a perfect world, each burner would have been "set and balanced" by final "quality control" at the factory.....
wait, is there actually a real Quality Control any more??
. Seriously, again, this is an easy DIY fix.
Mc
