The furnace itself is not in the ceiling. It's down low, on the floor, and the heating ducts are either just above or just below the floor.
If you have one of those snazzy new units, it may also have heat from the air conditioner, either resistive heat strips or running the air conditioner "in reverse," as a heat pump, to provide heat. This is suggested by your statement that you heard buzzing from the ceiling.
Did you actually check where the heat was coming from: floor ducts or ceiling ducts? Can you provide the model number of the air conditioner, to see if it has resistive heat strips or a heat pump mode? Can you tell whether the operating noise came from the furnace (grille under the refrigerator)? When the heat is running, can you go outside and CAREFULLY check the exhaust (back-to-back with the furnace inside? It will be REAL HOT if the furnace is running, cool if the heat is coming from the air conditioner.
If you can confirm that the air conditioner does have these features, and the exhaust is cool, this could be operator error--maybe read the manuals REAL CAREFULLY again. Or it could be the thermostat or controls in the air conditioner--beyond my scope.
Larry
