07-05-2022, 07:33 PM
Suburban oven pilot issues
My brother and I both have suburban ovens in our travel trailers. He has been having trouble with the popping pilot light and then unit going out. We took a look in mine since I wanted to show him how my pilot works and it does the same thing. My wife and I can get 20 minutes out of ours, long enough to cook a few biscuits but just like his it will shut off eventually. He has replaced the pilot, control unit and ordered a thermocouple.not sure if thermocouple will fix or not, but still the same prior to that.
Any ideas on this? My stove is in a 2018 camper, his 2010. Same symptoms. I don’t mind ordering parts but would be nice to hear some input on what might fix it. It seems really minor, as in mine almost works right.
07-05-2022, 07:45 PM
This could be just a bad connection on the thermocouple or thermocouple is not fully immersed in the pilot flame .
07-05-2022, 07:53 PM
This us a known issue with Suburban ovens in the mentioned years. Solved with a new pilot light assembly availabke from dealers only. Part is about $12 plus shipping and takes less than 30 minutes total. All wirk is done in oven with with a pair of wrenches and a phillips head screwdriver.
Has to do with wrong air passage size in pilot assy that results in an unstable flame that get's blown out when main burner transitions from heating to standby. Dealers were authorized to replace free under warranty but fuel to tow trailer to Dealer and back was many times the cost of part so I just bought it and replaced myself. Trouble free since.
Remove thermocouple/flame sensor from polot assy (slips out), disconnect gas line from pilot assy, remove assy from support with pgillips screwdriver. Reverse to assemble.
07-05-2022, 08:09 PM
My brother ordered and replaced the pilot, but is still having the same problem. I looked at it with him and we made sure the pilot was in line with the thermocouple... this was prior to him ordering the new control valve assembly.. and then new thremocouple.
I guess ill call my dealer tomorrow and see if they will help. The local dealers he called weren't very helpful and wanted him to bring his whole rig in and same as you too much fuel cost.
I'm guessing you just called your dealer and they sent you the part?
07-06-2022, 06:54 PM
MCTroy
Following since our oven won't stay lit either. Wish the part was available without going through the dealer. They will charge $30 for the $12 part.
2015 Windjammer 3029 Diamond Edition
2018 Ram 2500
Ohio River Rat
07-06-2022, 07:57 PM
I spoke to my dealer and they are going to see what they can do under warranty. I think you can order one online, but Not sure if it’s the revised part. I’ll update as I learn more
07-07-2022, 11:33 AM
The dealer I purchased mine from charged me $12 for the part and $14.95 for Shipping and Handling from Suburban.
07-07-2022, 02:45 PM
You don’t happen to have any record of the part # do you? My model number is SRNA3LBBS and want the updated pilot assembly. Dealer dragging feet
07-07-2022, 05:44 PM
I don't but check pdxrvwholesale.com. They stock Suburban parts and have model/serial number references.
Adding:
In my poking around I found that the latest P/N may be # 525036 but all sources seem to be out. An E-bay vendor claims delivery mid July for ~$20 incl shipping.
07-09-2022, 07:20 AM
Think she’s fixed
Adding:
So my brother had replaced his pilot with this one, along with everything else including the tc. Out of frustration, he took the pilot out again and with a very small instrument and jewelers glasses reamed the hole slightly. Re-assembled, works flawlessly.
Dealer working on getting me a new pilot… so I did the same thing. Jewelers glass, flash light to illuminate, and a small small needle slight tweaking of hole. I really could not see any physical difference. Reassembled; up to temperature (400) and not one sputter.
I was careful to not go too far, in fact I wasnt sure if I had reamed the pilot hole at all, and maybe I just cleaned some junk out of it… whatever the case, back in business of cooking biscuits and no parts needed.
