Old 09-18-2019, 08:00 AM   #1
Suburban SF-42 gas furnace not lighting
I have a SF-42 RV gas furnace that is not working. The blower runs about 10 seconds and then shuts off. I cannot hear the gas valve opening or the ignitor “clicking”. My research shows it might be a faulty sail switch. Is there a test to confirm this? Can the sail switch be replaced without removing the furnace. It is on a 2010 Cardinal. Thanks.
Mntman56 is offline   Reply With Quote
Old 09-18-2019, 08:39 AM   #2
Not ridiculously hard to pull it out but not fun either. When I had this problem I ordered a new sail switch and pulled the furnace out. The sail switch seemed to be clicking and working but it seemed to me that it was too straight. So I bent it a little more and shoved the furnace back in. That was 2 years ago and it's been working fine ever since. And I still have a backup sail switch. Don't know if this will work for you but sometimes something small can drive you nuts.
wherewolf17 is offline   Reply With Quote
furnace, gas, light, suburban
