Suburban Water Heater issue in Pup
Hi All,
Brand new pup owner here with a water heater issue that I need help with. Just brought home a new 2020 Rockwood 232ESP Folding camper. I had to drive 620 miles round trip to pick this up from an out of state dealer since none were to be found in my region of the country. Now that I’m home, I find an issue with the water heater that appeared to be working fine during the walkthrough at the dealership. On this camper the heater is located in the dinette slide out. I’ve found the only way the heater will light is if I push the slide out in a few inches during the ignition phase of the heater. If I flip the start switch with the slide out fully extended the heater will attempt to light but seems to be getting zero LP fuel and will not fire up. Push it in 3 inches and it fires right up. If I then pull the slide out all the way, the heater immediately goes out. Does anybody know what is causing this craziness?
