Old 02-19-2017, 04:55 PM   #1
ed9
Suburban Water Heater won't stay lit
Hi. The propane flame goes out after a minute or three minutes. Flame looks large when on. Checked for webs. Electric water heater runs good.
Have 2013 Rockwood Signature Lite.
Does the heating element run on electric? Or any other causes?
ed9 is offline   Reply With Quote
Old 02-19-2017, 06:33 PM   #2
HONDAMAN174's Avatar
Do you have water in it? Does the stove work?
Just glad to get away
Old 02-19-2017, 06:35 PM   #3
ed9
Yes stove works and water in it.
Old 02-19-2017, 07:12 PM   #4
McRabbet's Avatar
If it is like every other gas-fired appliance, there is a thermocouple that controls the gas valve so the gas will only flow if the pilot flame is on. I'm not familiar with the Suburban unit, but yours may need a replacement thermocouple.
Rob Payne
Hendersonville, NC
2018 Rockwood Ultra Lite 2304DS, 10K Equal-i-zer Hitch
2007 Toyota Tundra SR5 Double Cab 4WD 5.7L iForce V8
FROG Member since March 2017
McRabbet is offline   Reply With Quote
Old 02-19-2017, 07:15 PM   #5
wmtire's Avatar
Do you have the electric on at the same time as the propane? The electric heating element and the propane side work independent of one another and each have their own thermostat.
If both sides turned on:
If the electric heating element has the water already heated, then when you use the hot water (like taking a shower) and the temp inside the tank drops to a certain level, then both sides are going to start heating. The propane heats a lot quicker than the electric. Once the the water heats back up, then the thermostats for both side turns them both back off once the water inside the tank comes back up to the preset heated temperature.
If just the propane side turned on:
OR, is the water cold, and the propane never heats it up fully....with the electric heating element being off.
If you have a Suburban water heater, this thread may help:
http://www.forestriverforums.com/for...tml#post327988
2011 Flagstaff 831 RLBSS
I want to go to Bora-Bora, but I’m too Pora-Pora.
Old 02-19-2017, 07:44 PM   #6
Georgia Rally Coordinator
aceinspp's Avatar
How long has camper been siting? May have obstruction in gas jet area. Check for dirt from mud dubbers and or spiders . Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
aceinspp is online now   Reply With Quote
Old 02-19-2017, 08:02 PM   #7
ed9
Electric turned off. Propane never heard it. Flame keeps going out. No wonder. No spiders ECT. Thanks for the link.
Old 02-20-2017, 02:30 PM   #8
AKA: 'tiredTeacher
awellis3's Avatar
Do you have electronic ignition or pilot light?
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 02-20-2017, 03:02 PM   #9
ed9
Elelectic ignition.
Old 02-20-2017, 03:05 PM   #10
ed9
Also, my pilot light goes out every few minutes in my stove.
Old 02-20-2017, 03:29 PM   #11
But you said in post # 3 the stove works.
Is this the pilot in the oven?
What happens when you light a stove burner and try to light the water heater?
Sounds like a propane delivery problem.
Bad regulator, kinked hose, bad connector, etc.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 02-20-2017, 06:21 PM   #12
ed9
That's what I'm thinking. Stove works, oven pilot goes on and off. Will check lines.
Old 02-20-2017, 08:31 PM   #13
BillyBass's Avatar
maybe you have dirt in the line or you have air
in it
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
BillyBass is offline   Reply With Quote
Old 02-20-2017, 10:22 PM   #14
ed9
How do you get dirt out of a propane line? Or air?
Stove works good.
Old 02-21-2017, 04:36 AM   #15
It is possible that you are having problems with your regulator. My first check would be to get a manometer to check the pressures at the tank (11 inches on the water column) then regulator out put. (should be on regulator) Then check the appliance.
If you have dirt and crud you can clear the lines with compressed air. NOTE: propane is heaver than air and will puddle in low lying areas. With the proper mixture of air it could explode. Make sure to leak check all joints before calling the job done.
If all pressures check good it may be a flame verification problem and you should have a certified tech. look at it.
ka7cxa is offline   Reply With Quote
Old 02-21-2017, 09:28 AM   #16
DouglasReid's Avatar
X2
Im betting there is an obstruction somewhere. MUCH more common than a bad thermocouple. Besides, if it stays on for 3 minutes, the thermocouple is working just fine or it would extinguish as soon as you let go of the button or fail to light if it is DSI.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 02-21-2017, 11:49 AM   #17
ed9
Okay. Not into explosion. Thanks.
Old 02-21-2017, 12:15 PM   #18
AKA: 'tiredTeacher
awellis3's Avatar
Sounds right to me. Or those OPD valves on the tanks.
Wright and Penny
Richmond, Va.
Old 03-05-2017, 05:38 PM   #19
BillyBass's Avatar
you might have a cob web in it
Old 03-11-2017, 11:11 PM   #20
Crockett's Avatar
water heater in bypass could cause it to run for a few then shut off. check bypass. could have oil in lp line from reg to manifold. pull hose to reg and drain if necessary. check connections with soapy solution afterwards for leaks.
Crockett is offline   Reply With Quote
suburban, water, heater
