Old 04-24-2021, 01:54 PM   #1
The Newsoms's Avatar
Swapping dimmer knob for switch
I have a dimmer that is a knob. Turn to click on, then turn the knob until the lights are bright. I want to replace it with a toggle switch with a slider for dimming. Should this be an issue?
Jimmy & Teresa Newsom
2018 Riverstone 38RE/2019 Sundowner Toyhauler
2020 RAM 3500 SRW
The Newsoms is offline   Reply With Quote
Old 04-24-2021, 03:18 PM   #2
A switch is easy to install, but you can have both if you want; a dimmer and a switch that bypasses the dimmer. Just wire the new switch across the dimmer wires.
I have just the opposite, a light with a switch, but sometimes it's too bright. But rather than adding a dimmer, I'll just add one of these dimmable LED bar lights:
https://www.amazon.com/Gold-Stars-F3.../dp/B00EZX23S0
https://www.amazon.com/Dream-Lightin.../dp/B00WBD205W
nic7320 is offline   Reply With Quote
Old 04-24-2021, 03:46 PM   #3
Just make sure it is specifically for 12/24 volts DC and not a standard 110/120 volts AC dimmer:
https://www.superbrightleds.com/more...box/1181/2785/
You'll also need to make sure you have a deep enough space for it. Many RV outlets and switches are specifically for shallow wall spaces.
NavyLCDR is offline   Reply With Quote
Old 04-24-2021, 05:35 PM   #4
This I what I’m looking at.
Old 04-24-2021, 06:15 PM   #5
I don't see why it wouldn't work.
switch
