Thinking the A/C comp fried
Last year my trailer was setup for a while at a park with 30 amp power. Everywhere I go is 30 amp, trailer only has 1 a/c unit. Brisk 2, 13500.
One day I noticed the unit making some weird noise and not too cool inside. I turned it off. At the time i'd checked the power post and it was I want to say 108 volts or so (trying to go off memory)
I neglected to test/check it once back home and tried this past weekend. No cooling. The fan is running fine but no compressor.
I'm going to climb up there this week to check the compressor. From what I have figured out there should be 3 terminals on it. Ohm out from one to another checking for resistance. If there is any opens then it's bad. After that check from the body of the motor to the terminals. Looking for grounded circuits.
I remember a while back reading what low volts causes with the a/c. I can't remember though if it's the capacitors going bad or frying the compressor.
I guess final question is, can a compressor be replaced or are these things throw aways?
Thanks!
2017 GMC Sierra Denali HD
2014 XLR Hyper Lite 30HFS5
Toys-
Yamaha G9 Golf Cart
2010 Harley FLHX with lots of mods
