Originally Posted by RooBeDo
did you have to drill any holes into your trailer to install this camera? Was your trailer pre-wired for the furrion camera? If so were you able to use the holes drilled for that mount to install the new camera?
I did go ahead and purchase the furrion camera but am thinking of taking it back for a camera similar to the one you got, unless I have to drill new holes, if that's the case I'll just still with the furrion.
The vehicle I attached it to was a Pleasureway a class "B" Motorized RV.
The rear view wireless camera came with a camera which I mounted to the license plate frame. A transmitter which was mounted to the inside of the rear door was wired to the same wiring as camera. These were powered by the license plate light. The receiver was set on dashboard and plugged into cigarette lighter.
Turn the lights on and all devices, camera, transmitter and plugged in receiver powerup you backup camera is active.
With the lights in the camera and transmitter are active at all times the lights are on. So driving down the road the rear view camera is active as long as the lights are on. Helps driver in driving on the road and backing up. Just remember to turn lights off after use. Hopefully this helps.
BTW I don't have this vehicle any more. Stepped up in Class to an "A". Good luck and Happy Motoring.
